Kick down cable frozen - JeepForum.com
post #1 of 11 Old 12-07-2013, 02:08 PM Thread Starter
craftworks125
Every time it is below freezing my kicksown cable freezes. I only have like less than 1/4 throttle when it is frozen. After the trans heats up it thaws out and returns to normal. Any tips on how to fix this?
craftworks125 is offline
post #2 of 11 Old 12-07-2013, 03:08 PM
shaban
I'd just replace it. Or take it off, bring it in a warm room and sit it in front of the fireplace overnight. Maybe put some oil in it too.
shaban is offline
post #3 of 11 Old 12-07-2013, 03:42 PM
jay-h
Try to find a product called Dri-Slide (sometimes sold in auto stores or gun shops). It will penetrate right through the cable
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #4 of 11 Old 12-07-2013, 05:04 PM
somebody5788
1994 ZJ
I would also consider using WD40 as it's a water displacing spray and should in theory get rid of any water in the cable.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
post #5 of 11 Old 12-08-2013, 06:48 AM Thread Starter
craftworks125
I don't believe the problem is in the cable itself I think it is in the little shock things on the trans any pointers for that?
post #6 of 11 Old 12-08-2013, 07:05 AM
ZeeJay1997
If you are talking about the rubber boot on the cable, that is only an insulator to keep stuff out of the cable. If it is messed up, try soaking that area of the cable with wd40 as a temp repair, then order a new cable.
OEM p/n 52078672
ZeeJay1997 is offline
post #7 of 11 Old 12-08-2013, 08:32 AM Thread Starter
craftworks125
I can feel it slowly real ease as the jeep gets warm is it possible it is frozen in the transmission?
post #8 of 11 Old 12-08-2013, 08:40 AM
ZeeJay1997
disconnect it at the transmission lever and check movement of cable and lever.
post #9 of 11 Old 12-08-2013, 11:34 AM Thread Starter
craftworks125
Alright how do I disconnect it?
post #10 of 11 Old 12-08-2013, 01:09 PM
ZeeJay1997
I'm not sure and I cant find it in the FSM. I think it has retainer sleeve that slides forward, then move the cable back, then the lever ball lines up with the release hole.
I've had mine off a half dozen times, I always just get under there and figure it out. Maybe someone else can give you a for-sure method.
post #11 of 11 Old 12-08-2013, 06:36 PM Thread Starter
craftworks125
I got er figured out everybody thanks. I am going to buy a new cable.
