KG6MOV's Niner Build - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > KG6MOV's Niner Build
Smittybilt M1 Fender Flares + FREE Machete$40 off over $400 + FREE SHIPPING!!!Iron Rock Offroad products - get them from Kolak!
Unread 03-15-2013, 11:21 PM   #46
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
You're starting to find stuff like I did when I started tearing my niner apart. Consider yourself lucky--drywall screws look like a professional install compared to some of the crap I've found.
Sent from my iPhone 6 using JeepForum
In the garage: M1 4bbl
McCloudsZJ is offline   Reply With Quote Quick reply to this message
Unread 03-16-2013, 12:40 AM   #47
MTBlue
Originally Posted by kg6mov View Post
The wrong speakers showed up and got shipped back to amazon monday, wednesday the right speakers showed up AND they put money back in my account. Nice!
Setting up the speakers with the mounting bracket for 6 3/4 mounts.
Attachment 586207
Soldering straight to the speaker. None of this crimp extension crap. If you want to do it right, learn to solder.
Attachment 586208
All connected
Attachment 586209
And installed in the door.
Attachment 586210
Trusty box of trim panel retainer things. Never worry about breaking them off again, and of course there were quite a few missing already.
Attachment 586212
Front passenger side was just as bad as the drivers door was, installed with drywall screws. I made sure to double check the wiring colors in the FSM because I didn't trust the PO to have things installed in phase.
Attachment 586213
Rear driver side was nominal. Went to look at the rear passenger door and got a surprise.
Attachment 586214
The mechanical lock doesn't work either though the electronic part does so at least the door will lock.
Both the original screws for the door were missing, one had been replaced with a #10 sheet metal screw (WRONG AGAIN!). Once I opened the door panel it was easy to see why the window switch was missing.
Attachment 586215
Oh, and to top it all off, instead of three drywall screws for the speaker, the PO used ONE.
Classy.
Attachment 586211
Glass bits in the bottom of the door indicate the window broke if not worse. The car sounds much better now, just gotta do something about the sound bar in back and then the head unit. Want to take some measurments of the head unit and amp before I rip them out. Got to figure out what the funny eq thats on them is. Maybe replace the tweeters.
Also pulled the front driveshaft out. Need it for the trail jeep, and it wasn't fitting right in the niner anyway. I think the pinion yoke may be too damaged. Getting a lot better.
I think we had the same PO because I am finding the exact same things, down to the rear passenger window switch being broken the same thing and the PO using drywall screws to secure their speakers. WTF? No front DS, no front speakers, no amp, a shock that rattles, torn seat-backs and a broken sway bar end link. Somebody abused mine, then ripped out the internals. Who does that to a niner?
Dirt Deprived
MTBlue is offline   Reply With Quote Quick reply to this message
Unread 03-18-2013, 12:03 PM   #48
LRHostetler
@McCloudsZJ
"Sent from my iPhone 6 using JeepForum" I have a 4S, and herd the 5 sucks. how is the 6?
LRHostetler is offline   Reply With Quote Quick reply to this message
Unread 03-18-2013, 12:25 PM   #49
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
It's awesome.
Unread 03-18-2013, 12:41 PM   #50
kg6mov
kg6mov's Avatar
I've been thinking about getting one of those but I figured I'd still use my iPad Nano more anyway.
Sent from my iPad Nano using JeepForum
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 03-18-2013, 12:53 PM   #51
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Unread 04-02-2013, 08:30 PM   #52
kg6mov
kg6mov's Avatar
Front shocks (only?) showed up from kolak on friday. I didn't actually get around to hauling the box in from the porch until midnight. Had a lot of highway miles to do the next day, so on they went.
The entire front end is caked in dirt, need to get it to a steam wash before I do much more of this.
Shiny new bilstein vs crappy PO specials.
Would love an explanation on this one.
Both shocks went easy, almost too easy. Put the passenger side wheel back on and got a wobbly surprise! Checked ball joints and tre's both solid.
Judging by the missing axle nut covers on the wheels and the almost clean cv boots on the axles the PO did a cv axle job recently. And guessing that he isn't really the torque wrench owning type I figured it was probably safe to say he didn't torque them down properly. Which would mean the preload was wrong and the hubs are shot.
Yanked off the caliper and rotor, took a wrench to the axle nut and it came off way too easy.
Tried to shake the hub and got this instead.
Oh well, it's 2am. Pushed the hub back together, brake parts back on, axle nut torqued down properly. Wheel back on and no more shakes! Good enough for now, drove fine the next day.
Picked up new hubs today, haven't driven it since saturday but I need to figure out what is wrong with the front end on the green one, so I need this fixed.
It's only money.
Unread 04-08-2013, 01:12 PM   #53
kg6mov
kg6mov's Avatar
Got new wheel hubs in from o'reillys last tuesday. Brought em home and started ripping things out of the front end.
Passenger side came apart in a few too many pieces.
Front rotors were gouged and warped, pads were recent so the PO had probably never had the rotors turned. Pulled the cv shafts and didn't like what I found so ordered new ones.
The next day my parts pile looked like this.
Installing went great until I broke the bleeder nipple on the driver side caliper. O'reillys had two new ones in stock so I grabbed em, and a set of new front performance friction pads for good measure.
No pics of it together, towards the end I just wanted to get it driving, it was three days stuck in the garage in hover mode.
Unread 04-08-2013, 01:37 PM   #54
kg6mov
kg6mov's Avatar
Drove fine for two days, put a lot of miles in that time too.
Driving home from getting it washed (for the first time since I've owned it and probably the first time in a year or two of the PO) I start hearing a wubwubwub from the front end. Slow down 80 -> 50, the **** is that? *POW* front driver side drops a bit like the tire blew, ************, pull onto the shoulder and get another *POW* and the driver side drops more.
Tires don't blow twice.
All the lug nuts on the drivers side front wheel are gone, called AAA, tossed the jack under the frame and pulled the tire out to minimize body damage and waited to get towed home.
The CHP guy that showed up hops out of his car
"Broken down?"
"Yeh"
"Whats the problem?"
"Wheel fell off"
"It what?"
He stared at it for a while before he gave up and went off to write up some BMW's doing 70.
Shot of the hub on the tow truck, remains of lug nuts on all the threads, one stud is bent.
Ripped the front apart, pulled the rotor and hub, it was resting on the hub after the wheel gave up. Hadn't taken the core calipers back yet so I grabbed those and hauled off in the trail jeep to o'reilly's.
Who by some miracle had the hub in stock, warranty replaced. Threw the rotor on the lathe to check it, found a little bit of hop, warranty replaced. Grabbed lug nuts for the whole vehicle, cored the calipers. All together they owed me $13.
Swanky.
Really not a fan of coming home to this.
New parts, grabbed a torque bar set for the impact wrench.
My new lug nut procedure is impact with a 90ftlbs torque bar, then click wrench to 100ftlbs.
New hub went on easy, I'm getting a little too good at front end disassembly.
Now for some carnage. I don't have a shot of the fender, it was bent out of shape from sitting on the wheel. Bent it back in by hand but the paint is chipping. Here's the inside of the wheel.
Some pretty good gouges in the wheel.
Mounting area is totally trashed.
So now I need to get a new niner wheel. The jeep junkyard in sacremento has them for 100 clams a pop. Probably see about getting a fender from them too.
It really is only money right?
Unread 04-08-2013, 01:56 PM   #55
MTBlue
Good lord! You have horrible luck man, not gonna lie!
Dirt Deprived
Unread 04-08-2013, 03:00 PM   #56
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Those gore pictures make me want to cry...
Unread 04-08-2013, 04:48 PM   #57
kg6mov
kg6mov's Avatar
Good ****ing ***** mother of a ****sucking monkeys *****
For future reference:
This is a 16" niner wheel
And this is some major league bull**** has no business being on my jeep.
But in the dark at 11pm they look the freaking same. So I waited at Costco for two hours before they pulled the jeep into the bay and told me they can't mount a 16" tire on a 15" rim.
****, now I need two niner rims.
Unread 04-19-2013, 02:52 PM   #58
kg6mov
kg6mov's Avatar
Finally got a new niner rim and got the old tire put on it so I'm rolling again, just in time to build a bumper for the trail jeep.
New fogs for the price of used at the jeep yard will be going in when I have time to ate the bumper off, I've probably forgotten how running the green one without one for so long. Also gonna fix up some of the lock and door latch problems.
And I finally got my rear shocks from Kodak, so this is going to be riding great in no time.
Unread 05-29-2013, 10:15 PM   #59
kg6mov
kg6mov's Avatar
Little stuff
Bunch of little things since I haven't been on the forum in a while, well I've been lurking but haven't had time to post. Work has been a living ****storm.
Finally got the ac to work, all new hoses and dryer. And then the ****ing blower motor controller went out! Melted the connector too.
Replaced with this, and my special custom connector.
Replaced this,
With this,
Installed these, much brighter (front maps were out). I don't like them in the shifter bezels, but I think the interior lighting is going to go all led. Already put some in the green one too.
Swapped this so I can finally use the flipper glass, then I had to do the flipper glass gas shocks. Never ends.
And installed my new for the price of used (what a deal) fogs, so nice to have all the front lights working again.
Unread 05-30-2013, 04:16 PM   #60
JeepDaddy1993
you wouldnt happen to have a picture of the sound bar in the rear would you? ive been wondering how these are set up since ive never been graced with being in a 5.9 ive been trying to figure if i could make one or get one for my 96
JeepDaddy1993 is offline   Reply With Quote Quick reply to this message
