Keyless Entry - JeepForum.com
post #1 of 11 Old 07-31-2007, 09:42 AM Thread Starter
bz_711
Keyless Entry
I have 2004 Grand Cherokee Laredo - keyless entry only works if right up next to passenger door where module is located.
Dealership says $275 for new antennae transmitter/receiver...is there anything else that can be done or tried before replacing to extend range to opposite side of car?
Thanks for the help!
bz_711 is offline
post #2 of 11 Old 07-31-2007, 01:45 PM
merlinTec
merlinTec's Avatar
new batterys in fob?
merlinTec is offline
post #3 of 11 Old 07-31-2007, 02:31 PM
lostavatar
New battery as above, same thing is starting to happen to a friend of mine.
Yes, before you ask, I am a Jeep n00b. But, I'm willing to learn.
99 WJ 4.7L V8 Auto AWD
Intake, HIDs, Guards
2 12's 1200W 2ch, 600W 4 ch.
lostavatar is offline
post #4 of 11 Old 07-31-2007, 05:03 PM Thread Starter
bz_711
Please explain? I have put new batteries in remotes and they test at 100%. What is battery in fob?
bz_711 is offline
post #5 of 11 Old 07-31-2007, 05:28 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
There is a battery, in fact I think it is two batteries, inside the remote control for the Jeep. It is known as a fob.
On the side of the fob is a notch that you can use a dime in to seperate the two half's. I got my batteries at K-Mart and Radio Shack.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #6 of 11 Old 07-31-2007, 05:30 PM
merlinTec
merlinTec's Avatar
Hi
Sorry the fob is the remote. There is a TSB 08-011-03 for this fault (2003 year module)
http://www.wjjeeps.com/tsb_list.htm#0801103 part numbers
5JM61DX9AB Door Module, Passenger (WJ - Domestic Mkt.)
5JM63DX9AB Door Module, Passenger (WG - International Mkt.)
so the other way to do it cheaper is to fit the module yourself and then just pay the dealer to programe your remotes.
REPAIR PROCEDURE:
1. remove the passenger side door panel.
2. Remove the old door module from the passenger side door panel. The old
door module will not have an external antenna wire.
3. Install the new door module while temporarily routing the external antenna wire
along the door panel above the electrical wire harness.
4. If the vehicle is a WJ, route the external antenna wire through the two
support loops and tape the antenna to the door panel at two locations. The
WJ external antenna is 431 mm. (17 in.) in length.
5. If the vehicle is a WG, the external antenna wire is 533 mm. (21 in.) in length. Route
the WG antenna wire through both support loops and tape the antenna wire to the door
panel. Tape the remaining length of antenna wire to the electrical wire harness.
6. Install the passenger side door panel.
Book time is 0.3 hours so donít know how much the dealer was going to charge.
hope this helps
Regards
Merlin.
post #7 of 11 Old 07-31-2007, 05:35 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
Hi
REPAIR PROCEDURE:
hope this helps
Regards
Merlin.
Change the batteries first!!!!!!!!!
Lifetime member #13
post #8 of 11 Old 07-31-2007, 05:54 PM
merlinTec
merlinTec's Avatar
he has said he has done that.
post #9 of 11 Old 07-31-2007, 06:05 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
I am not so sure he has replaced the batteires in the FOB.
Besides, he has an '04 so the TSB should not apply. I have an '04 and had to change my batteries last year. It is about time for the batteries to be going bad on '04's
Lifetime member #13
post #10 of 11 Old 08-01-2007, 01:48 AM
merlinTec
merlinTec's Avatar
he says he has an 04 but the build date could well be an 03
post #11 of 11 Old 08-01-2007, 08:28 AM
ezrider327
I understand there is a TSB on it but here is something to try.
It may sound stupid but point the FOB / transmitter up at/under your chin, instead of pointing it at the vehicle. Not sure how it does it (somehow it uses your body like an antennae ) but this does increase the range of a Key FOB, I learned this trick from an alarm installer years ago. it WORKS.
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!! ESSAYONS
97 F350 Dually CC Powerstroke- - 65 Mustang - 74 Super Beetle - 93 Harley Sportster
97 ZJ 4.0 4x4 Auto : Rusty's BB lift & Rusty's K&N intake
235 75 15 Toyo Open Contry AT's 15x8.5 Eagle alloy's
Flowmaster exhaust, custom winch bumper, Ramsey 9000lb, THULE MOAB roof rack
ezrider327 is offline
Keyless entry grandcbs ZJ Grand Cherokee Forum 3 02-23-2008 09:52 PM
Keyless entry tracer ZJ Grand Cherokee Forum 6 01-31-2007 01:15 AM
Keyless entry Mr Q X ZJ Grand Cherokee Forum 2 07-19-2006 07:18 PM
Keyless Entry brillmtu ZJ Grand Cherokee Forum 2 06-06-2006 05:31 PM
95 Keyless entry ZJenvy ZJ Grand Cherokee Forum 10 09-14-2005 10:35 AM
