Key won't lock/unlock door - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Key won't lock/unlock door
New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!Poison Spyder DeFenders™ - "Tubeless" Jeep FendePoison Spyder Dana 44 Bombshells Are BACK!!
Unread 07-14-2007, 07:07 PM   #1
RobHawkins
2003 WJ
Just to make sure, I tried to unlock my 2003 WJ Laredo with my key. It doesn't work. So, I tried my other key. It doesn't work either. The remote works fine on both key sets but the key doesn't work at all. The tumbler rotates both directions but the locks don't operate.
If my battery goes out in my remote, I'm locked out at worst or I can't lock my WJ at best.
Help.
Rob
2003 Jeep Grand Cherokee Laredo. Best car I've ever owned.
RobHawkins is offline   Reply With Quote
Unread 08-18-2007, 09:56 PM   #2
phasewolf
If I remember right there is a plastic clip that can break or pop off it is white pull the door panel and you will see what I am talking about.
phasewolf is offline   Reply With Quote
Unread 08-19-2007, 08:11 AM   #3
ezrider327
That is correct, take the inner door panel off and look for the linkage that came unhooked.
I assume ( man I hate doing that ) it is only one door you are having this problem with.? You can still get in by using the other door
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!! ESSAYONS
97 F350 Dually CC Powerstroke- - 65 Mustang - 74 Super Beetle - 93 Harley Sportster
97 ZJ 4.0 4x4 Auto : Rusty's BB lift & Rusty's K&N intake
235 75 15 Toyo Open Contry AT's 15x8.5 Eagle alloy's
Flowmaster exhaust, custom winch bumper, Ramsey 9000lb, THULE MOAB roof rack
ezrider327 is offline   Reply With Quote
Unread 12-25-2007, 06:59 AM   #4
RobHawkins
2003 WJ
Thanks guys. Only the drivers door has a key lock.
Unread 12-25-2007, 07:25 AM   #5
Trouble Maker
Trouble Maker's Avatar
A lot of the newer vehicles are going that route. Anything to save a nickel on the assembly line.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline   Reply With Quote
Unread 12-25-2007, 07:47 AM   #6
droz
1997 XJ Cherokee
i had that same problem and my battery recently went dead but luckily had enough juice left to operate the locks. i guess its 1 more thing to add to the list of little things to fix
droz is offline   Reply With Quote
