Key, Steering Wheela and Shifter wont move - JeepForum.com
post #1 of 14 Old 12-27-2013, 01:41 PM Thread Starter
8valve
2007 WK
My 97 has been sitting for about a week. LAst time I used her was in the Ice Storm. Went to run her today and the Ignition Key, Steering Wheel and Shifter are locked. Its been very cold, sub zero during that period of non use. Any chance something has froze due to slush or ??
So how to you release whatever is causing the above mentioned problem. And how to you defeat whatever so this cant happen again. This my back up car for emergencies.
Thanks
8Valve
Build Super Kill Strong, Play Hard, Drive It Home
Toy Box; http://imageevent.com/moosecreekmaple
8valve is offline
post #2 of 14 Old 12-27-2013, 02:03 PM
durango-bob
2006 WK
I don't know how slush could have frozen in the ignition lock. But I have heard of the key turning problem being fixed by hitting the end of a key with a rubber mallet. There is even a youtube video that demonstrates it.
durango-bob is offline
post #3 of 14 Old 12-27-2013, 02:32 PM
JasonStebbins
I may be reading it wrong, but it sounds like the steering wheel is locked (safety feature). Turn it in either direction while turning the key to the "on" position at the same time and it should free everything up.
Poop
JasonStebbins is offline
post #4 of 14 Old 12-27-2013, 02:50 PM
SAR-Swimmer
Sometimes, turning the steering wheel slightly, will free up the key. Don't force it, just turn it slightly, while trying the key.
SAR-Swimmer is offline
post #5 of 14 Old 12-27-2013, 03:50 PM
Gearhead31
x3 on the safety lock. if I ever have the tires turned full lock on an incline or something, I have to force it to turn a tiny bit before the key will unlock. I've also known 6 other vehicles in the same rough era that has it. Try that and report back?
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #6 of 14 Old 12-27-2013, 06:25 PM Thread Starter
8valve
2007 WK
I understand what your suggesting, ie move the wheel a little each way. I have to do that wiht my Ram CTD sometimes. But the Jeep wheel will not move at all, the lock is holding it tight. The one suggestion to hit the end of the key with a rubber mallet, is that to break the lock position or just free the lock ?
How does one defeat this wheel/key/trans selector nightmare ?
8Valve
8valve is offline
post #7 of 14 Old 12-27-2013, 06:57 PM
mrgimble
2015 JK Wrangler
Jack up the front end and get the wheels off the ground and see of it helps. I would try that before beating on anything.
mrgimble is offline
post #8 of 14 Old 12-27-2013, 07:59 PM Thread Starter
8valve
2007 WK
I will try that in the morning. Snow and Ice, nice to have to work on a vehicle outside arrg
8Valve
8valve is offline
post #9 of 14 Old 12-28-2013, 01:36 PM Thread Starter
8valve
2007 WK
As suggested, I jacked the front end off the ground.
This still did not allow the steering wheel to move and let the key turn in the ignition. I tried tapping on the key with a small mallet..still no release.
This cant be the first time this has happened to someone. What has to be done to release the steering wheel,ignition switch and transmission selector so I can use the GC ? I can not even move it into my shop where its warm and lights.
Its wicked cold out to start just exploring. I cant find anything in the FSM that covers this lock up problem.
Thanks for any possible help
8Valve
8valve is offline
post #10 of 14 Old 12-29-2013, 02:21 PM
RNMedic
worn ignition lock cylinder. needs replaced
The only thing more powerful or reliable than a Warn is Chuck Norris getting out and pushing.. from Hussler on JF
RNMedic is offline
post #11 of 14 Old 12-29-2013, 04:40 PM
durango-bob
2006 WK
post #12 of 14 Old 12-29-2013, 04:57 PM Thread Starter
8valve
2007 WK
I went out this morning to try and figure the problem. Today was the first day in almost 2 weeks that was above freezing, 38 degrees.
I got in the CG, put the key in the ignition and it turned like normal. Did not do anything but insert the key and turn. Yesterday with temps in the Teens, it all locked up tighter that a drum.
As I first mentioned the last time I used the GC, it was slush and freezing rain. I am wondering if the key had water on it that got into the tumblers and froze.
I lubed her well with Graphite Key Cylinder lube and tried her tonight as its below freezing. Still works normal and easy.
Thats all I know, I am happy.
8Valve
8valve is offline
post #13 of 14 Old 12-29-2013, 05:04 PM
somebody5788
1994 ZJ
8Valve
I'm pretty confident the problem is in the steering. The gearbox could have water contamination internally or you could have iced up linkage.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
post #14 of 14 Old 12-29-2013, 07:13 PM Thread Starter
8valve
2007 WK
Yes, Iced up linkage is also possible due to the heavy slush that day. The same reason I never set the parking brake on any of my trucks in the winter.
I carry a 6x6 wood block cut as a tire wedge to use when parking int he winter on a grade.
8Valve
8valve is offline
