Key fob replacement - JeepForum.com
post #1 of 3 Old 05-25-2011, 11:35 PM Thread Starter
NapsterZJ
Key fob replacement
Is there anyway I can replace the OEM fob for my 95 ZJ with an aftermarket fob, or do I have to get a full security system?
It's starting to get obnoxious using my key to unlock it and sometimes missing the key slot and scratching my door
Thanks
1995 ZJ Laredo 4.0 - 5 Speed swap and 4x4 conversion, JKS KOR conversion and durometer bushings, Bilstein 5100s, fixed LCAs
DD - Stock 99 WJ 4.7 QD with flo 40
NapsterZJ is offline
post #2 of 3 Old 05-26-2011, 01:58 AM
BlueDevil
You could go to keylessride.com and you'll find a replacement FOB there. They also have'em on ebay, where you can also find an "original" one, from another Jeep of the same age (93-95 ZJ) - and they will work. Other years won't work.
I got the keylessride.com one because there weren't any originals for sale on ebay when I was buying, AND because I was told that those FOBs deteriorate over time because the infrared-emitting bulb-like-thingy gets scratched and what now, making the operating radius very small. Be that how it may, the replacement one works as the factory one - has to be pointed to the dome-thingy on the interior roof console. Radius is very small, but that's the IR system's flaw...
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
post #3 of 3 Old 05-26-2011, 10:46 AM
tcar
On Ebay... you can get good used replacement fobs. The less expensive ones have the paint on the buttons worn off, but if your buttons are good, it's an easy swap.
Also on Ebay, you can get aftermarket Fobs that work with the 93-95 GCs.
The instructions to set it are in your Owners Manual (and probably with the Fob).
Make sure you get a Fob that does NOT have a panic button... they won't work at all with a 93-95.
As Blue said keylessride.com also sells them on Ebay.
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
Tie Rod replacement help jeepon20 ZJ Grand Cherokee Forum 3 06-28-2010 02:00 PM
Need help with hub replacement squashman702 ZJ Grand Cherokee Forum 15 06-06-2009 03:47 PM
cat is going out. replacement? arsonist_bob ZJ Grand Cherokee Forum 11 11-25-2008 05:23 AM
94 5.2l oil pan replacement help! dsmjrv ZJ Grand Cherokee Forum 2 07-24-2007 08:08 PM
Tie Rod end replacement. . . RAZZMANIAC ZJ Grand Cherokee Forum 0 04-29-2005 09:03 PM
