Key Fob Doesn't Work. Help!?! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Key Fob Doesn't Work. Help!?!
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 04-06-2006, 05:30 PM   #1
Tamella2
I replaced the batteries in my keyfob, but it doesn't lock or unlock the car anymore. I followed the directions in the owner's manual and pressed unlock 8 times to reset it, but still nothing. Does anyone have any idea as to what could be causing this?
Thanks in advance,
Tami
Tamella2 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2006, 05:35 PM   #2
rrubio
If all you did was replace the batteries then it has to be the key itself.
rrubio is offline   Reply With Quote Quick reply to this message
Unread 04-06-2006, 09:41 PM   #3
SET2JET
did you check to see if the bat is in properly
SET2JET is offline   Reply With Quote Quick reply to this message
Unread 04-06-2006, 09:48 PM   #4
madcabbie
WHAT???
Did you try the other keyfob?
[B]99 WJ[/B]
4.0l|Westin Side Steps|Safari Bar|Pro Comp Explorer Lights| Rustys Catback|31in Yokahama Geolander AT II's|KOR 2.5in BB|V8 UC springs for a total of 3.5in Lift|Rubicon Shocks|OME SS|
Everytime Someone calls a Jeep, an SUV, [SIZE="4"]GOD[/SIZE] Kills a kitten.
madcabbie is offline   Reply With Quote Quick reply to this message
