Key Diagnosis Code Question - JeepForum.com
post #1 of 10 Old 11-28-2005, 08:26 PM Thread Starter
AWILD
AWILD's Avatar
So I read this FAQ
"Just the trick ..
to save you some money and avoid the dealership if you can fix it yourself.
How to get the codes:
Cycle the ignition key On - Off - On - Off - On within 5 seconds.
Count the number of times the check engine lamp on the dash flashes on and off. The number of flashes represents the trouble code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual two digit trouble codes.
Example: Lamp flashes 5 times, pauses, and flashes 5 more times. This indicates a code number 55. A code 55 will always be the last code to be displayed. This will indicate the end of all stored codes.
This method should work for Jeeps up to 1997 - I have yet to find a way of reading the codes on '98 TJ's or Cherokees/Grand Cherokees."
And got 33, 2, 55
How should I interpret that? Do all the sequences start with a 3, which would mean my code is a 32?
"An open or shorted condition detected in the EGR solenoid circuit. Possible air/fuel ratio imbalance not detected during diagnosis."
TJ
4.0L, 5spd, 2"BB, 31x10.5 Mud Terrains, Black Steelies,Hella 100W, Custom Brushguard, IPF H4 housings w/ Fatboys, Sirius 23 Hair Nation!
AWILD is offline
post #2 of 10 Old 11-28-2005, 08:28 PM
anticrombie
anticrombie's Avatar
no, you've got codes 33, and 2, the only code of that nature is the 55, the 'end of transmission' code.
Charlie
anticrombie is offline
post #3 of 10 Old 11-28-2005, 09:03 PM Thread Starter
AWILD
AWILD's Avatar
What's code 2?
TJ
AWILD is offline
post #4 of 10 Old 11-28-2005, 09:29 PM Thread Starter
AWILD
AWILD's Avatar
Correction - have redone my error codes. Ends up I am getting 12, 32, 55(end)
Code 12-Memory to controller has been cleared within 50-l00 engine starts.
Can someone interpret this for me?
Code 32-Exhaust Gas Recirculation (EGR) solenoid circuit-open or short detected in the EGR solenoid circuit/EGR system failure-required change in fuel/air ratio not detected during diagnostic test.
Is this due to no cat? Or should I be looking elsewhere?
TJ
AWILD is offline
post #5 of 10 Old 11-28-2005, 09:46 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
12 - Your battery has been disconnected within the last 50 starts.
32 - Your no cat, might have caused this, but I don't know.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #6 of 10 Old 11-29-2005, 07:55 AM
greasefingers
greasefingers's Avatar
1994 ZJ
First check to see that all the lines are connected to the erg valve. Then disconnect and re-connect the electrical connector; for starters. If the erg is not working then the air to fuel ratio will be rich, gas mileage will suck, and the engine could ping!
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #7 of 10 Old 11-29-2005, 04:58 PM Thread Starter
AWILD
AWILD's Avatar
egr valve...where's that. I need to buy a Chiltons
TJ
AWILD is offline
post #8 of 10 Old 11-29-2005, 05:29 PM
grandman17
where do you find the codes to see what they mean i no how to get them but how can you find out what codes are what
grandman17 is offline
post #9 of 10 Old 11-29-2005, 06:35 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Here ya go http://www.jeepsrus.org/index.asp?p=...s_Grand_93to97
About the code 32... is this the code that is sometimes thrown if the gas-cap is not sealed all the way?
EGR = Exhaust Gas Recirculation
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #10 of 10 Old 11-29-2005, 08:27 PM Thread Starter
AWILD
AWILD's Avatar
Here ya are
http://www.zjilla.com/tech_codes.htm
TJ
AWILD is offline
Computer Trouble Code Diagnosis! HELP!!! Andymack ZJ Grand Cherokee Forum 6 09-16-2013 10:11 AM
Tranny slips, which trans do I have and error code diagnosis please. 248152 ZJ Grand Cherokee Forum 2 02-08-2010 10:58 PM
Radio code question - option question... GARover WK Grand Cherokee & XK Commander Forum 5 12-25-2009 11:39 PM
Code question ynotyj ZJ Grand Cherokee Forum 2 03-14-2008 08:46 AM
Code Question? RAZZMANIAC ZJ Grand Cherokee Forum 2 02-14-2005 04:36 PM
