Kegger mod with EGR? - JeepForum.com
post #1 of 11 Old 06-21-2013, 04:22 PM Thread Starter
Freestyle713
1994 ZJ
So I picked up a second intake manifold to work on and put my aluminum plenum plate on, so I can work on it at my leisure. I figured I would do the kegger mod while I have the chance. My question is about the routing of the egr. The manifold directs the gases into the middle through a "tube" molded into the center divider, obviously to distribute them evenly between all cylinders. Since the kegger mod requires the removal of the center divider, it would remove this "tube" the gases travel through as well, which would cause the gases to just enter through the side of the manifold. My question is will this cause any problems? Since the gases won't really be evenly distributed anymore? Just wanted to play it safe.
You can see the "tube" in this pic
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #2 of 11 Old 06-21-2013, 04:55 PM
jm8881
I wonder if it's possible to cut around the egr tube. I don't know if the tube uses the center wall for support or not though.
jm8881 is online now
post #3 of 11 Old 06-21-2013, 06:06 PM
vonericsen
I haven't finished mine but I started cutting around the EGR tube. It's a pain. I'm subscribing to this so I know if I can just remove it...it would make things a lot easier.
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #4 of 11 Old 06-21-2013, 06:10 PM
dnuccio
i will be watching this too. too bad there wasnt a was to completely remove the egr system without popping a CEL
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 11 Old 06-21-2013, 06:42 PM
Kreeper
1994 ZJ
I'm in the same boat,I picked up a second kegger this morning to start modding so I guess we'll see how it goes.
Kreeper is offline
post #6 of 11 Old 06-21-2013, 11:42 PM
KJK
While my kegger doesn't have the EGR tube, when I modded it I left the center divider intact. I think the removal vs. non-removal benefits are minimal. Mine still pulls like a scalded ape. Just my 2 cents...
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #7 of 11 Old 06-22-2013, 11:28 AM
FAlfani81
I didn't even know about this mod... I'm interested in seeing where this is going.
FAlfani81 is offline
post #8 of 11 Old 06-22-2013, 04:51 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I read somewhere, maybe speedfreaks.net, about someone 'modding' the kegger and actually getting less torque at the dyno. I would just deshroud the injector bosses and smooth out the runners and call it done.
HighLonesome is offline
post #9 of 11 Old 06-26-2013, 05:46 PM
Kreeper
1994 ZJ
Well it's done,hot tanked and a run through the bead blaster to get it clean,smoothed out all the runners and injector ports and gasket matched it to the fel-pro gaskets before a high heat paint job and Hughes plate kit.
Kreeper is offline
post #10 of 11 Old 06-27-2013, 08:05 AM
HighLonesome
Nice. So you didn't shorten the runners or mess with the divider? Looking forward to your SOTP opinion.
post #11 of 11 Old 06-27-2013, 01:26 PM
Kreeper
1994 ZJ
Nope,didn't change much other than cleaning up all the inside casting flaws and the port match,ill let you know how it goes once I get my cam and start the install.
Kreeper is offline
