Keeping it alive! - JeepForum.com
post #1 of 18 Old 03-30-2012, 10:53 AM Thread Starter
tmcgraw
Keeping it alive!
Hello everyone!
I have a 5.2L ZJ Jeep and recently bought it it just crossed over the 200,000 miles area. I don't have much of a history or anything on this Jeep and was wondering what are some things you all would recommend at this mile range to check on these?
I'm going to be replacing the exhaust gaskets this weekend, that looks fun ...
Probably looking at a CV soon too, any other things I might be on the look out for soon or I can replace now to avoid catastrophe later on?
Thanks for all the help in advance! I'm hoping to have a long life here.
tmcgraw is offline
post #2 of 18 Old 03-30-2012, 11:06 AM
Heepish
Welcome to JeepForum
I would add an oil change to your list, if you aren't sure when it was last done. You could also do a tune up (plugs, wires, cap, rotor) for the sake of knowing they are brand new.
1998 Grand Cherokee 5.9 Limited - Completely bone stock for now
1996 Grand Cherokee 4.0 2WD Laredo - Suprise for the grandfolks
1994 Chevy Silverado 1500 4X4 - Plow Truck
1993 Honda Del Sol Si - Parked good weather DD
Heepish is offline
post #3 of 18 Old 03-30-2012, 12:17 PM Thread Starter
tmcgraw
Probably not a horrible idea either! I forget simple things a lot of times! Haha
tmcgraw is offline
post #4 of 18 Old 03-30-2012, 12:30 PM
vonericsen
If it is burning oil, the plenum gasket is likely bad.
Check the transfer case for binding because at that mileage the VC might be bad too. (do figure 8's in a parking lot to check for binding).
BTW, Welcome to the forum!
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #5 of 18 Old 03-30-2012, 12:46 PM Thread Starter
tmcgraw
So while I'm out doing figures 8's and having a blast, am I listening for popping? grinding? Or is it one of those things where I'll just know?
I know everywhere I park it I get a little tranny fluid on the ground, but it always seems topped off, does the x-case have it's own reservoir somewhere?
tmcgraw is offline
post #6 of 18 Old 03-30-2012, 12:48 PM
sebian
Couple things come to mind other than what was listed above. I am probably leaving a few things out too.
Change differential fluids
Change tranny fluid and filter
Coolant flush
New air filter
Check all bushings, including motor and tranny mounts
Grease all zerk fitings in suspension and drive shafts
While greasing, check condition of all boots on the tie rods
Check condition of ball joints
Check condition of wheel hubs
Edit: while you are doing the figure 8's listen for any tire squealing (unless you hit some paint), feel for any wheel hopping, or unusual clunks.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #7 of 18 Old 03-30-2012, 12:49 PM
PolkaPower
It will feel like it's binding up really bad and very wobbly. Probably leave black tire marks on the ground. For the plenum you need to pull the throttle body off of the intake and shine a really bright flash light in there all the way to the back. If its leaking you will see oil puddled up.
PolkaPower is online now
post #8 of 18 Old 03-30-2012, 12:54 PM
Heepish
Its something where you'll just sorta know. I know the VC in mine is bad, and if I make a tight turn, it feels like the front end is trying to skip or hop.
Heepish is offline
post #9 of 18 Old 03-30-2012, 01:11 PM
JColee
It usually has to warm up a bit before it will do this correct? I never noticed that mine was bad until i drove three hours across state. Also, when I parked and turned off the Jeep, it would jerk forward because i was on a slight incline.
JColee is offline
post #10 of 18 Old 03-30-2012, 01:13 PM
PolkaPower
Depends on how worn out it is. Mine would do it right from the start.
post #11 of 18 Old 03-30-2012, 01:37 PM Thread Starter
tmcgraw
You guys have given me a list to go through now! I'm pleasently surprised honestly.
This Jeep's future is going to be off-road and taking me and some friends back int othe woods to hunt (Ohio). I would like to be able to trust it in most weather conditions.
I've been driving it daily but I'm sure most of you are aware of where gas prices are now and I get about 13 mpg through traffic. I'm just a dealership parts guy, I'm not rich enough to drive it on my 75 mile daily commute haha.
tmcgraw is offline
post #12 of 18 Old 03-30-2012, 01:45 PM Thread Starter
tmcgraw
Also, it's taking longer to start now than say 3-4 weeks ago, I hear lots of rumor about the crank position sensors going bad? Would this be somethign I can be proactive on? Sound like something normal?
tmcgraw is offline
post #13 of 18 Old 03-30-2012, 01:48 PM
PolkaPower
If you haven't changed those sensors and want to be sure they are working it's a good idea to put some new ones in. Keep the old one's as spares just in case.
post #14 of 18 Old 03-30-2012, 01:48 PM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Distributor, rotor, wires, and plugs.
New air filter.
New injectors.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #15 of 18 Old 03-30-2012, 02:42 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by tmcgraw View Post
Hello everyone!
There are no exhaust gaskets at the manifold. I don't think the donut connection at the y-pipe uses gaskets either.
ratmonkey is offline
maintenance
A/c - it's alive! DAHEMI WK Grand Cherokee & XK Commander Forum 6 07-11-2011 06:28 AM
Its Alive! JrMechanic ZJ Grand Cherokee Forum 1 02-01-2009 06:58 PM
It's ALIVE!!! but a few problems... Vestjam ZJ Grand Cherokee Forum 3 03-15-2007 08:30 PM
HELP...my horn is alive. JamesEric ZJ Grand Cherokee Forum 1 05-09-2005 06:05 PM
Its Alive !!!! todd17063 ZJ Grand Cherokee Forum 1 04-17-2005 12:41 AM
