K & N fipk install help - JeepForum.com
post #1 of 2 Old 12-07-2002, 08:00 AM Thread Starter
chris311
i have a 97 4.0L and i just purchased a K&N fipk and began to install it yesterday. everything went smooth until i got to the step where i had to do something with the EVAP canister. the installation instructions said to disconnect the EVAP line from the canister and route it to the right side of the intake. i was not sure what this was and the directions were not very clear. can anyone help me out?
chris311 is offline
post #2 of 2 Old 12-07-2002, 09:25 AM
Beachead19
Beachead19's Avatar
From Haynes manual:
"-The EVAP canister is located at the front of the left fender, under the headlight."
So its on the drivers side, near the washer fluid reservoir, and as the Haynes says, under the headlight.
Hope that helps a bit...
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
Fipk ? nierace ZJ Grand Cherokee Forum 7 03-15-2007 03:32 AM
K&N FIPK bacaruda ZJ Grand Cherokee Forum 9 12-01-2005 04:18 AM
K&n Fipk bacaruda ZJ Grand Cherokee Forum 3 11-28-2005 04:38 AM
K&N FIPK install problem...need help bullet ZJ Grand Cherokee Forum 10 07-09-2005 08:02 AM
Pix from my K&N FIPK install Jillie ZJ Grand Cherokee Forum 10 03-22-2004 10:25 AM
