Just got replacement PCM - JeepForum.com
post #1 of 58 Old 07-05-2013, 11:41 AM Thread Starter
reynoldsjp
I bought a used PCM for my 98 Grand 4.0 on Ebay. I got it today. Anything special putting it in ? Just make sure battery cables are undone and put it in then hook battery up ? It has exactly the same number as my old and security built in as well. Any help asap is greatly appreciated. I am excited to see if I can get this moving after sitting for almost a month due to lack of funds.
reynoldsjp is offline
post #2 of 58 Old 07-05-2013, 11:47 AM
dellis
2005 WK
Did you get the VIN and mileage programmed into it? My understanding is that beginning with the 98 model year, the VIN has to be programmed into the PCM for it to work (since the mileage is stored in the '98s PCM, I suppose there's some sort of Federal law that requires a sanity check on the VIN).
dellis is offline
post #3 of 58 Old 07-05-2013, 11:58 AM
dakimbrough
Great PCM Change
Just remember to add your mileage to the PCM before installing.
dakimbrough is offline
post #4 of 58 Old 07-05-2013, 12:04 PM Thread Starter
reynoldsjp
How do I get that done is it expensive ? Can I run it without getting that done and not have any problems other than mileage display ?
post #5 of 58 Old 07-05-2013, 12:35 PM
ZeeJay1997
talk to Coralman, he has a 98. IIRC it will work with no programming. put it in to see if it works.
ZeeJay1997 is offline
post #6 of 58 Old 07-05-2013, 12:55 PM Thread Starter
reynoldsjp
Ok. So I put it in hooked battery back up. My jeep started right up ! Actually the best start it has ever had. No hesitation or cranking before starting just started right up. Mileage was correct and security works. Thanks to all for quick responses and help. I am going to drive it for a few days and see if my stalling issues have gone away. Until the next item breaks I bid you farewell.
post #7 of 58 Old 07-05-2013, 01:28 PM
dellis
2005 WK
Good for you! Looks like I was wrong ...
dellis is offline
post #8 of 58 Old 07-05-2013, 02:27 PM
MeanGreenZJ
Goes to show how much bad info gets passed around.
MeanGreenZJ is offline
post #9 of 58 Old 07-05-2013, 02:30 PM
dellis
2005 WK
If you note, my guidance on programming was softened (because I just didn't have any personal experience with it) ... but, I had felt it was fairly reliable since it was once posted by ratmonkey.
dellis is offline
post #10 of 58 Old 07-05-2013, 03:54 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I referenced the info about 98's before, because I had heard that it needed the vin programmed. But, on the last cardone I got under warranty it was not vin programmed if I remember correctly. I have a backup that was rebuilt by another company and even though they asked for the vin I have no idea if it was actually entered. It would be interesting to see if the OP's vin is original or not using a drb.
Originally Posted by HighLonesome
coralman is offline
post #11 of 58 Old 07-05-2013, 06:21 PM Thread Starter
reynoldsjp
Well I have been driving it all day and no issues so far. I hope this is truly the end of the stall issue. Is there a place that buys old ones for remanufacturing ? I took it buy the wash and got it all cleaned up. So at least for now I'm back on the road.
post #12 of 58 Old 07-05-2013, 08:22 PM
ZeeJay1997
i dont know of one. rat hole it, maybe you can use it for a core sometime... or take it apart and try to fix it.
post #13 of 58 Old 07-05-2013, 08:40 PM
Oldfrog
2007 WK
What I've come to learn about the 96-98 PCMs for the 4.0 is that quite often, there is something else wrong in the system that fries them. Not always....but often. For instance, myself having a background in electronics, I know that the making and breaking of poor power connections ( usually grounds) will wreak havoc on integrated circuits and certain discreet components.
Yes, I believe that some of the PCMs were just plain crap to begin with...but others have been fried... and much too easily, if you ask me.
Keep the old one....if might get you home one night if it works at all...
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #14 of 58 Old 07-05-2013, 08:44 PM
ZeeJay1997
OP, Oldfrog makes a good point. It would be a good idea to disconnect the battery and clean the grounds on side of the block
post #15 of 58 Old 07-06-2013, 12:29 PM
dakimbrough
jeepgrandcherokeepcm.com......Great website for PCM .
