Just got my 97 ZJ! have a few problems, need help! - JeepForum.com
post #1 of 7 Old 02-19-2012, 08:56 PM Thread Starter
BRae_in_a_ZJ
I just got my first Jeep today! A nice 97 ZJ with a few minor mods. 125k miles. everything runs well with a little character ofcourse.
Major problem: My ABS light is on. not quite sure what to do about this...
also my tires are rubbing if i cut the wheel 100%, i can only cut the wheels about 85% then they start to rub. anything i can do?
Thanks for any advice! Im just starting so thanks!
'97 5.2 Laredo "Maggie"
BRae_in_a_ZJ is offline
post #2 of 7 Old 02-20-2012, 01:27 AM
norcalzj
I had a hell of a time getting my tires to turn without rubbing , had to trim the fenders and then actually beat in part of the wheel well at the bottom by the front door , that was a pain since its all part of the unibody. then folded the wheel well seem over as far up as I could .. as far as the abs I couldn't tell ya , luckily I haven't had problems with it .. "yet"...
norcalzj is offline
post #3 of 7 Old 02-20-2012, 06:01 AM
oldsixinarow
I have owned a number of ZJ's over the past few years and probably half have had an ABS light on. In my experience, removing the ABS module from under the ABS pump, sending it to BBA Reman in Mass., and reinstalling it upon its return gets rid of the ABS light on the dash. Getting the module rebuilt costs $100 and it's worked every time for me. Plus, you can still drive the car while the module is out, because the abs wasn't working before you sent it out anyway. Lifetime warranty on the repair too. Check out their website: http://www.bba-reman.com/US/index.aspx. You'll need to email them for information on having your module rebuilt as our cars are old enough that it's no longer listed on their website. It's an "ATE" brand abs module, though, and you'll see that is the major brand they repair. Volvo and Ford also used ATE modules, so there's tons of them out there...
A Bunch of ZJ's, A TJ, A CJ2A and an FSJ
oldsixinarow is offline
post #4 of 7 Old 02-20-2012, 06:27 AM
joeyb629
if your MAJOR problem is the abs light being on, then you are a lucky man. mine was on when i bought my 97 ZJ, took the bulb out of the dash so i don't have to look at it anymore.
joeyb629 is offline
post #5 of 7 Old 02-20-2012, 06:39 AM Thread Starter
BRae_in_a_ZJ
The guy i bought it from has already tucked the fenders in about an inch but i will see what else i can do without breaking anything... like i said its not a huge problem. thank you so much!
post #6 of 7 Old 02-20-2012, 06:41 AM Thread Starter
BRae_in_a_ZJ
Thank you so much i will certainly do this. it seems well worth the money. Much appreciated!
post #7 of 7 Old 02-20-2012, 06:42 AM Thread Starter
BRae_in_a_ZJ
Thank a bunch! ill see what i can do
abs , tire rub , tire rubbing , zj
Some problems Psyco6string WK Grand Cherokee & XK Commander Forum 2 11-09-2009 02:41 PM
Mudding problems.....What do you guys do to prevent problems? JackAysJake ZJ Grand Cherokee Forum 8 02-23-2009 09:02 PM
4Lo problems UTChavok ZJ Grand Cherokee Forum 9 03-18-2008 09:12 PM
A/C problems DagCarson ZJ Grand Cherokee Forum 1 02-25-2007 06:28 PM
Alternator problems??? Shock problems??? rflem550 ZJ Grand Cherokee Forum 11 01-24-2007 06:41 AM
