Just got my 1st jeep! Few questions.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Just got my 1st jeep! Few questions..
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 04-10-2011, 04:57 PM   #1
herm25
So I have done a little browsing and just curious about the suspension of my ZJ. from bottom of fender to center of hub: front 19'' rear 20''. is this stock height?
I have also found it has JKS quick disconnects for the swaybar.
a cold air intake.
and some sort of power module like i have never scene.
i will attempt to attach a photo to help you judge susspention.
it has Hancook Dynapro MT 31x10.50 R15
ok can not firgure out how to add a photo here. but ther should be one on my profile.
herm25 is offline   Reply With Quote
Unread 04-10-2011, 05:15 PM   #2
JFcavedweller
JFcavedweller's Avatar
definitely lifted at least 3 inches, 2" larger than stock tires... you sir have a nice jeep
O|||||||O
JFcavedweller is offline   Reply With Quote
Unread 04-10-2011, 06:04 PM   #3
KingtheZJ
stock measurement for bottom of the fender to center of hub is 18". it might have coil spacers or something like that. check the tops of the coils. also, does it have aftermarket lower control arms. factory are stamped steel and aftermarket will be tubular.
'98 ZJ with stuff
Build Thread
http://www.jeepforum.com/forum/f197/1-500-1-170-a-1388735/
KingtheZJ is offline   Reply With Quote
Unread 04-10-2011, 06:25 PM   #4
herm25
The lower control arms are factory, and I did not see any spacers around the shocks...
below is a link to the photo bucket album of all the pics i have taken, there are many of the under carage.
www.photobucket.com/97zj
http://www.photobucket.com/97zj
Unread 04-10-2011, 06:31 PM   #5
underpowered
underpowered's Avatar
looks like about 2" to me. i would bet coil spacers. looks killer though
1998 ZJ 2" bb and 31's. street queen but sees the woods once in a while.
2000 powerjoke tow pig
Anti-jeep--1989 K5 blazer. the new off road ride
underpowered is offline   Reply With Quote
Unread 04-10-2011, 06:51 PM   #6
Corrupt
If no spacers it might be a F>R swap...(just a thought though). Does it have the CV or u-joint front axles? <--might be a newbie question, but good stuff to know.
[B][center]***If you try to fail and succeed, then which have you done?***[/center][/B]
[center][color=white][i][b]1998 Jeep Grand Cherokee Limited--5.2L[/b][/i][/color][/center]
****[color=yellow]___________ [/color]*******************[color=white]____________[/color]**************
****[color=yellow]//"T"l[___i___] [/color]*****************[color=white]//__||_||_\\___\\_____[/color]********
****[color=yellow][----T---L-OlllllllO-][/color][color=red]_______________[/color][color=white]d-/ \_|__|_/ \_[ ]\\\\\[ ][/color]********
*****[color=yellow]() )""""""() )/"**\) )[/color]***************[color=white]( )_)=o=( )_)=o=( )_)[/color]********
Corrupt is offline   Reply With Quote
Unread 04-10-2011, 07:02 PM   #7
JFcavedweller
oh yeah, looks like 2" spacers, still nice clearance for the 31s . those look like aftermarket shocks that have been painted over too. theres some rust but from what i can tell from the pics it doesnt look bad, could probably use a good underside wash though.
stock axles - CV front, standard back. 2" of lift isnt going to warrant any mods like that
O|||||||O
Unread 04-10-2011, 07:58 PM   #8
KingtheZJ
appears there are 2" coil spacers. they sit on the coil, not the shock.
and you may want to look into replacing the front driveshaft with one that has a ujoint at the pinion. the cvs are notorious for failing when you start lifting and offroading.
'98 ZJ with stuff
Build Thread
jks , lift , suspension , zj
