just finished 247 to 242HD swap, now having shifting problems - JeepForum.com
post #1 of 6 Old 07-24-2009, 07:47 PM Thread Starter
kmd1776
so i just finally finished my tc swap in my 04 wj.
i also installed the new select trac shifter.
now for some reason, i cant seem to get the shifter working with the transfer case. when i go under the jeep and manually shift it, it works great. but when i try using the shifter, it doesnt work. it just binds and doesnt wanna move without alot of force. ive been tryin to adjust the eyelet that connects the shift cable to the shifter itself, but that doesnt seem to be doing it. what could be the problem here???
04 wj limited; 4.7L V8, 247> 242hd swap; Hayden auxillary tranny cooler; BFG All Terrain 245/70/17; Moog Up-Country Coil Springs; Monroe Reflex Monotube Shocks; JKS BPE's; Chrome Overland tow hooks; Dynomax Ultraflow catback
kmd1776 is offline
post #2 of 6 Old 07-24-2009, 08:04 PM
sandman
did you use the 242 shift tab?
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 6 Old 07-25-2009, 05:27 AM Thread Starter
kmd1776
what do you mean by shift tab?
kmd1776 is offline
post #4 of 6 Old 07-25-2009, 07:10 AM
Zwildm30
http://jeephorizons.com/tech/tcase.html
1998 Jeep Grand Cherokee 5.9 Limited
Zwildm30 is offline
post #5 of 6 Old 07-25-2009, 07:30 AM
skain8
skain8's Avatar
You have to change the linkage position on the transfer case from top (247) to bottom hole (242). If you didn't, it will not shift properly with input from the shifter. It's mentioned in both of the popular write-ups out there for this swap.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #6 of 6 Old 07-25-2009, 04:21 PM Thread Starter
kmd1776
thanks skain8.... must have missed over that when i read it the first time. went back over it and it was right there with pics included
swapped it to the right hole and it works great now. thank you.
kmd1776 is offline
Jeep WJ 247-242HD Swap nierace WJ Grand Cherokee Forum 801 02-23-2017 07:31 PM
247 to 242HD swap questions Kramer H ZJ Grand Cherokee Forum 11 12-10-2013 05:54 PM
247-->242HD Swap, where to buy wiring? bill38jeep ZJ Grand Cherokee Forum 15 01-17-2010 12:10 PM
247-242HD swap help reconbyfire ZJ Grand Cherokee Forum 6 02-13-2009 01:27 PM
247 -> 242HD swap "Yoke question" UUJ1 ZJ Grand Cherokee Forum 4 04-18-2008 02:18 PM
