it just died????? - JeepForum.com
post #1 of 8 Old 01-29-2007, 09:48 PM Thread Starter
rustycherokee18
it just died?????
I'm just crusin through out local spot on my way to nice crick crossing when my jeep just dies?? So the fun begins. I check to see if my fuel pump is kickin on and it is. So i move to the ignition system. I pull a plug and ground it out will still hooked to a wire and crank it....and no spark. I check to make sure everything is connectd and such. I have no ideas as to what it coulb be?????? could it be my coil?? or rotor or what??
rustycherokee18 is offline
post #2 of 8 Old 01-29-2007, 10:14 PM
Naturalhoosier
Naturalhoosier's Avatar
How's your battery??? Mine did this in December. I was just going down a road and at a stop light it just died. I couldn't get it to do anything. Changed the battery and haven't had a problem since.
--Nick
My Ride: 1998 GC Limited
Colorado Jeep Club Member #15
Black Jeep Club Member #1976
Make the world a better place, punch a Boilermaker in the face!!!
Don't blame me...I didn't vote for him.
Naturalhoosier is offline
post #3 of 8 Old 01-30-2007, 08:30 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Did I ever mention that I hate ignition coils? I had about five or six die in less than 4 years...
I would place a bet on that.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 8 Old 01-30-2007, 03:27 PM Thread Starter
rustycherokee18
I had my friends jumper cable just hookd to it while i tried starting and it cranks over like a champ but just doesnt start so i dont know
post #5 of 8 Old 01-30-2007, 03:40 PM
greasefingers
greasefingers's Avatar
1994 ZJ
1- You could pull the distributor cap and make sure that the rotor has not melted (I have seen this once)
2- Then I would test the resistances of the coil.
3- If coil is good then I would replace the crankshaft position sensor.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #6 of 8 Old 01-30-2007, 03:43 PM Thread Starter
rustycherokee18
Rotor is fine that was the firs tthing i checkd to make sure. as for the other 2 im was going to check the coil today and then if its bad replace it then if its good ill check option 3.
post #7 of 8 Old 02-03-2007, 07:19 PM Thread Starter
rustycherokee18
could it be due to a bad alternator??
post #8 of 8 Old 02-04-2007, 06:36 AM
greasefingers
1994 ZJ
I do not think that the alt is your problem.
Cheers Steve
everything just died xjhavens ZJ Grand Cherokee Forum 4 10-14-2009 01:14 AM
CD player died tomiko ZJ Grand Cherokee Forum 4 01-18-2009 11:47 AM
Jeep Died :-( adgjqetuo ZJ Grand Cherokee Forum 6 09-05-2006 09:42 PM
My '02 GC Died This Morning - Help. KellyN ZJ Grand Cherokee Forum 15 01-24-2006 08:56 AM
zj died! papashango ZJ Grand Cherokee Forum 21 01-07-2005 04:18 PM
