-   -   it just died????? (http://www.jeepforum.com/forum/f13/just-died-368255/)
rustycherokee18 01-29-2007 10:48 PM
it just died?????
I'm just crusin through out local spot on my way to nice crick crossing when my jeep just dies?? So the fun begins. I check to see if my fuel pump is kickin on and it is. So i move to the ignition system. I pull a plug and ground it out will still hooked to a wire and crank it....and no spark. I check to make sure everything is connectd and such. I have no ideas as to what it coulb be?????? could it be my coil?? or rotor or what??
Naturalhoosier 01-29-2007 11:14 PM
How's your battery??? Mine did this in December. I was just going down a road and at a stop light it just died. I couldn't get it to do anything. Changed the battery and haven't had a problem since.
Texas ZJ1 01-30-2007 09:30 AM
Did I ever mention that I hate ignition coils? I had about five or six die in less than 4 years...
I would place a bet on that.
Hunter
rustycherokee18 01-30-2007 04:27 PM
I had my friends jumper cable just hookd to it while i tried starting and it cranks over like a champ but just doesnt start:brickwall so i dont know :confused:
greasefingers 01-30-2007 04:40 PM
1- You could pull the distributor cap and make sure that the rotor has not melted (I have seen this once)
2- Then I would test the resistances of the coil.
3- If coil is good then I would replace the crankshaft position sensor.
rustycherokee18 01-30-2007 04:43 PM
Rotor is fine that was the firs tthing i checkd to make sure. as for the other 2 im was going to check the coil today and then if its bad replace it then if its good ill check option 3.
rustycherokee18 02-03-2007 08:19 PM
could it be due to a bad alternator??
greasefingers 02-04-2007 07:36 AM
I do not think that the alt is your problem.
The time now is 06:52 PM.
