Just did my 6th water pump in the last 3 years - JeepForum.com
post #1 of 22 Old 04-27-2013, 09:02 AM Thread Starter
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Second Flowkooker in a row. Before that 2 Mopars. Before that 2 NAPA. The NAPA ones were junk and started making bearing noise. The 4 Flowkoolers and Mopars all started leaking from the weephole. I'm wondering WTF.
HighLonesome is offline
post #2 of 22 Old 04-27-2013, 09:55 AM
jm8881
Are you using the correct belt? Is your clutch fan in good shape? The only thing I can think of that will continually kill water pumps is too much stress on the bearings.
jm8881 is offline
post #3 of 22 Old 04-27-2013, 10:02 AM
riot1987
6 seems a bit excessive ..I dont even change my oil that often in 3 years
Build thread^^
riot1987 is offline
post #4 of 22 Old 04-27-2013, 10:40 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Still using a clutch fan?
ratmonkey is offline
post #5 of 22 Old 04-27-2013, 02:22 PM
lostbiker
Sounds like a bad clutch fan I would switch to the e-fan I'm about to that one I get my heater core and fuel pump taken car of
lostbiker is offline
post #6 of 22 Old 04-28-2013, 10:09 AM Thread Starter
HighLonesome
I was running the Mopar efan but I switched to clutch fan about a year ago. Doesn't seem to matter. The Flowkooler instructions say the pump might leak through the weephole at first until the seal laps in. I'm going out to look now.
She ran great yesterday. Never went about 200*. 70* day.
post #7 of 22 Old 04-28-2013, 10:57 AM
Uniblurb
Uniblurb's Avatar
Know you know how to tension a belt but are the pulleys lined up straight on your 5.9 transplant? Any pulleys replaced like PSP? Bypassing your AC compressor which doesn't work? Just digging for suggestions....
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #8 of 22 Old 04-28-2013, 11:49 AM Thread Starter
HighLonesome
AC compressor is long gone. I have the recommended shorter belt.
The belt is aligned perfectly and there is no obvious wear on the belt.
The new water pump is not leaking! See how long that lasts.
post #9 of 22 Old 04-28-2013, 06:00 PM
Foundrydude
Same truck for all these pumps? You may have some casting sand or other grit moving through the system
Foundrydude is offline
post #10 of 22 Old 04-28-2013, 07:08 PM Thread Starter
HighLonesome
Could radiator stop leak cause it?
post #11 of 22 Old 04-29-2013, 05:57 AM
newfieZJ
Can't say yay or nay from experience but it sure sounds logical to me .
newfieZJ is offline
post #12 of 22 Old 04-29-2013, 07:38 AM
riot1987
Ive heard that **** isnt too good for your cooling system. Whens the last time you flushed everything?
Build thread^^
riot1987 is offline
post #13 of 22 Old 04-29-2013, 07:41 AM Thread Starter
HighLonesome
Never.
I replace the coolant that I drain when I do the water pump, which is often.
Guess its time.
post #14 of 22 Old 04-29-2013, 07:45 AM
riot1987
Never.
Guess its time.
Give it a shot. Im not 100% positive but I could see some of that filler gunk getting places where it shouldnt be and causing some issues
Build thread^^
riot1987 is offline
post #15 of 22 Old 04-29-2013, 07:47 AM Thread Starter
HighLonesome
thanks
I'm even going to drain the block if I can get the plugs out.
