Just Checking Before I Replace the Oil Pan Gasket - JeepForum.com
post #1 of 4 Old 03-23-2013, 12:56 PM Thread Starter
jt_armstrong
1994 ZJ
Guys
This morning I have replaced the rear main oil seal and fitted a new oil pump. Having reviewed various threads on the forum, there are no shortage of methods for actually replacing the oil pan. Some say fit the seal to the block first and other say fit the seal to the pan first.
What is the best way to complete this task? Also is it worth running a bead of RTV around both sides of the gasket or just stick to the corners as per the service manual?
jt_armstrong is offline
post #2 of 4 Old 03-23-2013, 01:20 PM
jm8881
As long as both gasket surfaces are clean and true then you shouldn't need any rtv and more often than not both surfaces are true enough to seal without anything other than a gasket.
jm8881 is offline
post #3 of 4 Old 03-23-2013, 01:27 PM
KJK
I RTV'd the corners per the service manual. I had the gasket on the pan and used a few pieces of tape to hold it in place while offering it up.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #4 of 4 Old 03-23-2013, 07:26 PM Thread Starter
jt_armstrong
1994 ZJ
Thanks guys. Gasket now on. I used a little RTV to hold the gasket to the pan and a little more as directed on the block. Wont know how sucessful it has been until tomorrow when i have finished all the other things on my todo list.
