Quantcast Just Changed the transfercase fluid! wow. . - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Just Changed the transfercase fluid! wow. .
Poison Spyder BFH Rear BumpersFront and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yo
Old 10-24-2009, 11:28 AM   #1
Max78
Well I finally got around to changing the Transfer case fluid in my Jeep and . I put the front tires on ramps and pulled the fill plug then the drain plug. It drained less than a quart and it was Black! It currently has 107k on it. I'm guessing the PO didn't touch it.
I pushed it off the ramps so it was level and proceed to fill it. I was only able to get about 1.5 quarts in before it came spewing out of the fill hole. I keep reading that it takes 2 quarts but i cant get it to take the rest.
I have the NV242HD and used ATF+4
Another strange thing is that before i changed the fluid I had what seemed like valve train noise but after it was changed it went away. Very strange. . .
02 Grand Cherokee Sport 4.7 Selec-Trac / Red Jeep Club Member #374
- Dynomax Super Turbo - K&N FIPK!!!
Max78 is offline   Reply With Quote
Old 10-24-2009, 11:38 AM   #2
JrMechanic
Transfer Case Guru
JrMechanic's Avatar
It only takes 1.5 quarts.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
http://www.jeepforum.com/forum/f13/np249-np231-np242-swap-information-updated-685644/
JrMechanic is offline   Reply With Quote
Old 10-24-2009, 09:12 PM   #3
PTCHBLKZJ
did that valvetrain noise sound like a knock ?........ maybe i should look into this
PTCHBLKZJ is offline   Reply With Quote
Old 10-25-2009, 01:24 PM   #4
Virmagicus
Headed Out West
Virmagicus's Avatar
Could have been motor oil as well. Never know ...
Virmagicus is offline   Reply With Quote
Old 10-26-2009, 09:03 AM   #5
Max78
It was ATF, Also it must have been a fluke about the valvetrain noise. Because its back. . . damn!
Glock Forum
