just change my water pump!! - JeepForum.com
post #1 of 3 Old 09-14-2012, 09:32 PM Thread Starter
lostbiker
Learned how to change out my water pump i spent 165 bucks my garage quoted me at for $400 so i did it my self it was easy just time consuming too me about 4 hours to do it. I got a new belt for $38 and coolant for $15
2012-09-14_10-04-56_456.jpg   2012-09-14_10-05-03_759.jpg   2012-09-14_10-05-16_375.jpg   2012-09-14_10-51-06_448.jpg
lostbiker is offline
post #2 of 3 Old 09-14-2012, 09:35 PM Thread Starter
lostbiker
Still need to buy the hard line that runs to the heater core a new thermastate and thermostat gasket
post #3 of 3 Old 09-15-2012, 07:14 AM
newfieZJ
Just to mention a few tips . Your only 6-8 bolts away from having much better access by removing the Alt and AC , then swing it towards the pass side . That by-pass hose should be replaced with the w/pump too . Moving the ac/alt bracket gice easy access to the t-stat , and changing the by-pass hose .
newfieZJ is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 05:50 AM
When to change water pump (4.7 XK) hinchcliffe WK Grand Cherokee & XK Commander Forum 1 07-07-2011 01:56 PM
Water Pump Leaking - Can I just change the gasket? cracked ZJ Grand Cherokee Forum 16 10-19-2009 09:22 AM
4.0 water pump change - need guide stuart_smrt ZJ Grand Cherokee Forum 2 04-16-2009 07:22 AM
ZJ 5.2 water pump change sniper0423 ZJ Grand Cherokee Forum 3 11-01-2007 10:04 AM
