Just bought Jeep needs Serpentine belt? - JeepForum.com
post #1 of 15 Old 07-26-2009, 08:10 AM Thread Starter
MuddyNiner
Okay so I bought a Jeep a 2001 WJ for $2,000 it needed tires bad so i took it to get tires yesterday and they asked if i wanted an oil change so i firgured what the heck. Well after he was done the guy said I need a new serpentine belt and said they'd do it for $140 but i looked at it and it is a little cracked should I replace it? Also My left rear tail light stopped working all together it was dim and i put a new bulb in it and now it doesn't work at all? What should I do?
MuddyNiner is offline
post #2 of 15 Old 07-26-2009, 09:47 AM
cmonson
that sounds like a great deal for a belt that costs about $30 and 5 mins to change.
As for the rear brake light, I would check all fo the connections 1st. Verify your grounds are OK.
cmonson is offline
post #3 of 15 Old 07-26-2009, 09:53 AM
WiCkeDuDe
WiCkeDuDe's Avatar
5 minutes might be a little long. Maybe 1 minute slip off and 1 minute slip on.
WiCkeDuDe is offline
post #4 of 15 Old 07-26-2009, 11:10 AM
terryj
2015 WK
Hell yes, I'll replace serpentine belts all day long for $140 a belt. Two things any driver should know, how to change a tire and how to change a belt.
terryj is offline
post #5 of 15 Old 07-26-2009, 12:40 PM Thread Starter
MuddyNiner
okay i replaced it. it was $45 at autozone and took 20 mins but was a pain in the *** to get around the A/C compresseor. Thanks for the help now if only i could get my tail light working i can go get this thing registered monday morning. Any ideas?
post #6 of 15 Old 07-26-2009, 02:17 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
take the housing off, check the connections on the bulb socket, then check the cicuit board for cracked or burnt connections. if none of those apply, get an new taillight housing like every other wj owner has to.
ratmonkey is offline
post #7 of 15 Old 07-26-2009, 03:27 PM
CaptainDCD
Dude, the belt is super easy to do, 10 mins max....just need a wrench and the routing diagram it under the hood.... paying that much labor is insane...$25 for a decent belt and about $40 for a good one at any local parts store.. I recommend the Goodyear Gatorback...
CaptainDCD is offline
post #8 of 15 Old 07-27-2009, 07:55 AM
xjhavens
man i want that guys job!!!! 145 bucks!!! thats like 10 bucks a minute labor!!! where do i sign up?
xjhavens is offline
post #9 of 15 Old 07-27-2009, 01:09 PM Thread Starter
MuddyNiner
alright i found the problem, apparently this is a common problem with the 2000 grand cherokee is when your headlights are on the left brake light doesnt work but when they are off it works fine. so i just gotta buy new lights.
post #10 of 15 Old 07-27-2009, 01:38 PM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
wait whaaaaat? that doesn't make any sense- what in the light would just cause it to not work when the headlights are on. It really sounds like a bad ground somewhere.
2010 JK 4-Door Unlimited Sport- Soft top, V6, 6-speed standard, bone stock for now
YJMCBoy is offline
post #11 of 15 Old 07-28-2009, 07:18 AM Thread Starter
MuddyNiner
where are the grounds for the light at?
post #12 of 15 Old 07-28-2009, 04:45 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's the housing shorting out, it's so common you may as well buy a new set of tail lights when you buy a wj.
post #13 of 15 Old 07-28-2009, 05:36 PM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
I stand corrected, I didn't know this. Thank you Ratmonkey, learned something today.
YJMCBoy is offline
post #14 of 15 Old 07-28-2009, 06:06 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
when we stop learning we're dead. always something new to know out there.
post #15 of 15 Old 07-28-2009, 06:09 PM
xJoshxx
2012 WK
yup wj's use a circut board type for the rear 1 plug 3 bulbs Controlled by Switches and relays and puters lol
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
How do I get my serpentine belt off? 4.0L 02Lightning ZJ Grand Cherokee Forum 20 05-10-2016 08:41 PM
Serpentine belt for 04 mmacnish ZJ Grand Cherokee Forum 5 06-22-2008 12:42 PM
Serpentine Belt Nofear6372 ZJ Grand Cherokee Forum 8 05-16-2008 09:41 AM
5.9 serpentine belt... help! aletheuontes ZJ Grand Cherokee Forum 2 12-27-2007 10:27 PM
Serpentine Belt LargeFather ZJ Grand Cherokee Forum 8 09-01-2007 07:56 AM
