Just bought a 96 5.2 ZJ PLEASE HELP !!!! - JeepForum.com
post #1 of 11 Old 05-01-2013, 09:45 PM Thread Starter
Jramos43
I just bought it and now the check engine light is on. Took it to auto zone and they gave me a paper saying :
No change in map sensor voltage from koeo to koer
Detected no change in MAP sensor voltage.
Failed map sensor
Shorted signal wire
ECM Defective
Now I am new to ZJ 's so please help me out as to how i fix this please. Thank you
99 WJ
96 ZJ
Jramos43 is offline
post #2 of 11 Old 05-01-2013, 10:08 PM
JohnCrabtree
1994 ZJ
Failed map sensor
Shorted signal wire
ECM Defective
99 WJ
1999 Grand Cherokees are WJs (as you correctly said at the end of your post) not ZJs. This subforum might be a bit more help.
JohnCrabtree is offline
post #3 of 11 Old 05-01-2013, 10:14 PM Thread Starter
Jramos43
I know, I used to own a WJ and I forgot to take off my signature
99 WJ
96 ZJ
Jramos43 is offline
post #4 of 11 Old 05-01-2013, 10:18 PM
JohnCrabtree
1994 ZJ
99 WJ
Ah, okay. Well, I'll let more experienced guys chip in here as I have no idea how MAP sensors actually work (I've never even pulled mine off and looked at it). Although this gives me an idea for what to do while I clean my throttle body.
post #5 of 11 Old 05-01-2013, 11:57 PM Thread Starter
Jramos43
Thanks. Glad I could help
99 WJ
96 ZJ
Jramos43 is offline
post #6 of 11 Old 05-02-2013, 07:20 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
It's a diaphragm that gets moved by manifold vacuum.
Either the orifice is obstructed, the sensor is bad, or possibly wiring.
Use the "key trick" and post the code from your odometer so know exactly what the pcm is seeing.
ratmonkey is offline
post #7 of 11 Old 05-02-2013, 06:08 PM Thread Starter
Jramos43
I got codes 12 13 77 55
96 ZJ
96 ZJ
Jramos43 is offline
post #8 of 11 Old 05-02-2013, 06:55 PM
dusterdude
Can i assume the jeep is running crappy?
dusterdude is offline
post #9 of 11 Old 05-02-2013, 08:12 PM
AnotherRedZj
96 ZJ
12 means there's a problem found
13 is MAP sensor
77 is speed control relay
55 means end of codes
AnotherRedZj is offline
post #10 of 11 Old 05-02-2013, 08:56 PM Thread Starter
Jramos43
dusterdude: no the jeep runs fine. And strong
96 ZJ
96 ZJ
Jramos43 is offline
post #11 of 11 Old 05-02-2013, 08:57 PM Thread Starter
Jramos43
bmeyst : alright thanks.
96 ZJ
96 ZJ
Jramos43 is offline
