Junkyard Lift? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Junkyard Lift?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 09-12-2007, 06:49 AM   #1
kdavis
Junkyard Lift?
It seems that for lifts under 4", it's really just a spring swap and shocks, right?
I did a search, but didn't find anything on this, so...
Has anyone here figured out a junkyard lift setup? In other words, which springs from which rig, if any, are compatible with the Jeep to give this kind of lift? Is it possible to just go to the salvage yard and find some off an old ford or chevy, or whatever?
Not sure if this is the way to go, just asking the question. Thanks!
<>< KD ><>
What I Have: 1994 Grand Cherokee Limited
2.25" 4 Wheel Customs Spacer Lift
Cragar Soft 8's, High Tech Retreading OTR Muds, New Front End
What I Do: MT Web Guy
kdavis is offline   Reply With Quote
Unread 09-12-2007, 07:13 AM   #2
wheelNC93
I know you can do a f>r swap....take your front springs put them in the rear and buy 3.5 or 4" coils for the front ( overall 3.5-4" lft). I dont know a whole lot about it though i'm sure someone else will fill in the details for me.
94 GC Laredo 5.2L -BDS 6.5" coils-TeraFlex upper and Lower Adj. Control arms F&R-TrXus 33x12.5x15 on 15x8 rockcrawlersz -TeraFlex Discos-JKS adj. trackbars-249<242 swap (in progress)-RRO t-case skid-off road warehouse sliders-Custom roofrack - 4 Hella 500's - herculined interior
wheelNC93 is offline   Reply With Quote
Unread 09-12-2007, 07:50 AM   #3
kdavis
I've seen that F>R, I've only seen it with retail packaged springs though. My rig has a gajillion miles on it, so I'm sure i have spring sag anyway. I'd like to see if anyone knows what springs will get me lift. I'm likely buying the 2.25" KOR spacers, so if I could get another 2" out of some springs, I'd be good, plus some new shocks.
<>< KD ><>
Unread 09-12-2007, 08:07 AM   #4
Katesdad
Katesdad's Avatar
I wish it was that simple.
Katesdad is offline   Reply With Quote
Unread 09-12-2007, 08:30 AM   #5
Yardman Harry
O
Yardman Harry's Avatar
Your best bet is to do the F>R, this will give you more spring travel, and its fairly cheap, otherwise you will be buying both the front and rear 2 inch lifting coils.
YOu can get a set of Front Rancho springs for 150 dollars.
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline   Reply With Quote
Unread 09-12-2007, 08:30 AM   #6
Derek33
over 3" or so youre going to want to look into track bars.
i heard something about older f-250 springs fitting up front? not sure though.
Derek33 is offline   Reply With Quote
Unread 09-12-2007, 08:43 AM   #7
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i hear some of the XJ guys use coils out of F150's.....their springs are the same diameter as ours.
but F150 coils are WAYYYYY!!!!! stiffer, and u will get allmost no flex.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote
Unread 09-12-2007, 12:18 PM   #8
JeepZJ94
1994 ZJ
I used the f150 springs before. There is some flex there but not really what i would call good. I have the v8 so the ride wasnt as bad as it would be on an I6.
Why dont Money Grow On Jeeps?
1994 Jeep ZJ. 5.2L Engine, 3.5" Lift. 15x7 Steel Wheels w/BFG AT's, Push bar with 6" lights. Factory tow package. Bigger tires to come and much more.
RnR 4x4 Club
JeepZJ94 is offline   Reply With Quote
Unread 09-12-2007, 01:43 PM   #9
kdavis
You have basically the same rig I do, so was the $30 3.5" the f150 springs, or something else? Did you do both front and back?
<>< KD ><>
Unread 06-08-2008, 09:48 AM   #10
grey50beast
1994 ZJ
What I would do is swap the front to the rear, then put the f150 springs in the front. I want to do this plus use my 2.25" BB on top of that.
-Jon
1994 ZJ 5.2 Limited: Muddy, 31" Dakota MT, 2.25" BB, bedlined all to hell.
Soon to come: home fabbed sheetmetal front bumper
1991 Mustang: TOOOOO MUCH!!!
grey50beast is offline   Reply With Quote
Unread 06-08-2008, 09:24 PM   #11
snakester14
what id do is get some new front V8 springs and put them in the rear their like 60 bucks then get 4 inch springs for the front then shocks but im not sure on the track bars.
1998 ZJ 5.2/2inch bb/265 a/ts/Flowmaster SOLD
1996 Stock XJ 4.0/ax-15/231 Traded
1998 4.0/ax-15/231 TJ on 33s SOLD
snakester14 is offline   Reply With Quote
Unread 06-08-2008, 09:40 PM   #12
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
Search around; I've heard of people using Thunderbird coils instead of the F150 coils. They're the same height I believe but a softer ride...
COTM - October 2012! - It's for Sale! - Click Here!
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Unread 06-10-2008, 10:32 AM   #13
jhammond_82
someone said about a $30 spring swap. for 20 bucks more on ebay you can get a 2" spacer, or are those not woth the money? (i'm kind of new to this)
jhammond_82 is offline   Reply With Quote
Unread 03-21-2012, 05:13 PM   #14
PHARIS88
I have a 2004 I6 WJ, I already have 2'' daystar BB installed, I would like to have about 3'' of lift with not having to spend more than a couple hundred bucks, does anybody have a straight answer to what setup I could do to gain more inchs? Don't want to go any higher than 3.5'' because I don't want to deal with changing the driveshaft, track bar, control arms and what not. If I do the F>R swap what do I put on the front? Would like it explained to as easily as possible
If you ain't Texan you ain't **** :)
www.youtube.com/pharis88
www.jeepforum.com/forum/f22/1996-zj-grand-cherokee-pharis88-build-thread-1507279/
PHARIS88 is offline   Reply With Quote
Unread 03-21-2012, 06:14 PM   #15
PolkaPower
If you find a genie tell her I want a 3.5" lift that rides great for 200 bucks too.
98 5.9 2"BB, Custom V-Tec mod, high performance muffler elves, alloy performance lug nuts, super high flow custom radiator cap, Ultralight unobtanium flywheel, stage 6 ultralight hydro tuned wiper blades(front), kevlar stickers
[QUOTE=JohnnyZJ;13325401]if its to tall for her to get into why don't you just install some running boards?[/QUOTE]
[QUOTE=HAMAR;13330720]I just gave her ironing board, she's not getting another board.[/QUOTE]
"What is best in life?
"To crush your enemies, see them driven before you, and to hear the lamentations of the women."
PolkaPower is offline   Reply With Quote
