junkyard 44a Qs? - JeepForum.com
post #1 of 6 Old 11-22-2008, 12:29 AM Thread Starter
sandman
junkyard 44a Qs?
picking a ZJ 44a up soon and plan to take it from a u-pull-it bone yard. this is what i know to look for. 3.73, pinion and axle seal leaks, LSD. i could do without LSD but would be happier with it. main question: i know that the 44a has been known to have bearing issues, what should i check to make sure the bearings are ok? any other suggestiona would be appreciated also.
Edit: also im pretty sure i will need to shorten my DS. should i go that route or should i just pull the DS with the axle? also how much shorter is the 35 DS from the 44a DS, 2"? not sure.
thanks
john
1993 Jeep ZJ. 4.0
sandman is offline
post #2 of 6 Old 11-22-2008, 05:23 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
take the driveshaft too.
hard to check rear bearings without it being in a vehicle.
going to be 3.73's unless they were swapped.
lsd is hard to find, the 5.9 limiteds came with them standard.
ratmonkey is offline
post #3 of 6 Old 11-22-2008, 05:32 AM
Katesdad
Katesdad's Avatar
Break your 35 or just planning for something else?
Katesdad is offline
post #4 of 6 Old 11-22-2008, 06:16 AM Thread Starter
sandman
yea, not broken yet. just time for an upgrade. honestly i think i could run my set up forever with no major problems. im pretty easy on the gas. but gears, trimming, an hp30 and 35s are somewhere in the future and this is just one step closer to where i want my jeep to be. putting the MVC skid/truss on it too.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 6 Old 11-22-2008, 06:21 AM Thread Starter
sandman
hoping this wasnt the case. theres really nothing to look at? or listen for? or wiggle? or something. if i do buy an axle with bad bearings, how dificult is it to replace them? not sure how the guts work. so theres a bearing on each side of the carrier and 2 on the pinion right? either or i will need to know how to set up gears to replace them right?
1993 Jeep ZJ. 4.0
sandman is offline
post #6 of 6 Old 11-23-2008, 02:31 AM Thread Starter
sandman
no one? bump.
1993 Jeep ZJ. 4.0
sandman is offline
97 ZJ Junkyard upgrades? Gibby913 ZJ Grand Cherokee Forum 21 01-04-2013 09:54 AM
Junkyard Lift? kdavis ZJ Grand Cherokee Forum 17 03-21-2012 07:56 PM
have DW - going to junkyard spikeystrip ZJ Grand Cherokee Forum 8 07-21-2009 01:33 PM
Junkyard Find DTrem08 ZJ Grand Cherokee Forum 12 10-23-2007 12:12 PM
mods from junkyard BustedZJ ZJ Grand Cherokee Forum 11 04-29-2007 08:53 AM
