Junk yard lift - JeepForum.com
post #1 of 17 Old 09-06-2009, 10:00 AM Thread Starter
zjdamien
1977 J-Series Truck
Junk yard lift
Ok got a 93 zj with 4.0 l6 what's the most lift I can get from a junk yard lift I heard u can put the V8 front springs on the rear and get 4 inches so what can I get for the front
zjdamien is offline
post #2 of 17 Old 09-06-2009, 10:10 AM
Jones
Consider the following...
Jones's Avatar
The cheapest lift you can do is a 2" Budget Boost.
The next cheapest is a 3.5" front to rear swap that uses your front springs in the rear and all the components you see here.
IRON ROCK OFF ROAD: ZJ 3.5" Lift Kit
The I6 springs net the same amount of lift as the v8 springs so you'll be fine there.
Jones is offline
post #3 of 17 Old 09-06-2009, 10:25 AM
Darthteddy
1955 M-38
I heard a long time ago that Coils out of Certain older model Ford Pickups (F150s) would fit ZJs and would net alotta lift. Cant remember if anyone ever tried it tho. I know their alot stiffer and im pretty sure their the same diameter. I wanna say it was either early 90s or late 80s F-150s. Thad be your ideal Junkyard lift.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #4 of 17 Old 09-06-2009, 12:51 PM
Jones
Jones's Avatar
The spring rate from those would equal a horrible ride quality. I'd stay away from that option.
Jones is offline
post #5 of 17 Old 09-06-2009, 01:17 PM
BLACKzj52
say what
good, im not the only one who has heard about that then lol
people thought i was crazy when i brought that up once
BLACKzj52 is offline
post #6 of 17 Old 09-06-2009, 01:27 PM
Jones
Jones's Avatar
Originally Posted by BLACKzj52 View Post
say what
I can never remember who it was, I think sadass, tested both sets of springs and they both had the same amount of lift.
Jones is offline
post #7 of 17 Old 09-07-2009, 12:22 AM
StellaTheZJ
I've tried V6 XJ Springs (almost no lift, and sooo soft it had horrible handling ), ZJ I6 springs (a little over 3", stock ride and handling), and ZJ V8 springs (about 4" quite a bit stiffer than stock). I went with the I6 springs because the V8s were stiffer than I want in a DD.
Also, on stock control arms, I had more vibration with the 4" than I wanted.
StellaTheZJ is offline
post #8 of 17 Old 09-07-2009, 02:57 AM
sandman
yep.
1993 Jeep ZJ. 4.0
sandman is offline
post #9 of 17 Old 09-07-2009, 08:34 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Maybe you can find a ZJ with a lift in a junkyard...
Brian
WJ, WK, CJ5
GraKee99 is offline
post #10 of 17 Old 09-07-2009, 04:48 PM
deltl1ks
I'm planning on doing this as well.
Can you just do the below, or do you have to buy the kit above? Would a new set of OEM shocks work in the short run on this lift?
I have a part's Grand Cherokee V8 so I have the V8 springs front and rear. Planning on removing my ZJ front springs to the rear and installing the front v8 spring's on the my ZJ front.
Sounds like the v8 springs all the way around would be a rough ride compared to what I'm looking for based on the above thread.
Those of you whom have done this, what are your thoughts on it?
deltl1ks is offline
post #11 of 17 Old 09-07-2009, 04:59 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you can't just put springs in and call it a day...there's a lot of other things to attend to in a 5 link suspension set up.
ratmonkey is offline
post #12 of 17 Old 09-07-2009, 05:03 PM
Jones
Jones's Avatar
The rear of your jeep would be sitting 3.5" higher than the front. The front to rear swap uses stock front springs in the rear and new 3.5" springs for the front. You can't use stock springs on all four corners and expect a level lift. The kit I posted earlier has what you need.
Jones is offline
post #13 of 17 Old 09-07-2009, 05:07 PM
blackjack12982
1994 ZJ
Just putting V8 springs in your Jeep won't net any lift. To do the F>R, you put V8 springs in the rear of your Jeep, and put 3.5" springs in your front. However, many people have complained about that ride being pretty harsh. You can get 3.5" springs all around for not too terribly much money.
All that being said, there's much more than just throwing 3.5" springs on your ride. You're gonna need adjustable trackbars and new shocks at a minimum. Do yourself a favor and read through the FAQ's, it explains many, many things, this as well.
blackjack12982 is offline
post #14 of 17 Old 09-07-2009, 05:07 PM
blackjack12982
1994 ZJ
Beat me to it!
post #15 of 17 Old 09-07-2009, 06:35 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
If you do a 'Junk Yard' lift, you will get exactly what is implied by the name.
JUNK.
If you want junk, have at it.
If you want better, save your $$ and do it right.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
Junk Yard Finds krm944 ZJ Grand Cherokee Forum 18 12-08-2008 04:26 PM
Junk Yard Prices? adgjqetuo ZJ Grand Cherokee Forum 8 11-05-2006 08:33 AM
Advice on getting a 231 from the junk yard Zaphod ZJ Grand Cherokee Forum 7 01-03-2006 05:34 AM
How to indentify the 242 in a junk yard? Zaphod ZJ Grand Cherokee Forum 15 12-24-2005 11:18 PM
Saw a ZJ at the junk yard verrive ZJ Grand Cherokee Forum 6 03-11-2004 02:15 PM
