Quantcast JKS front trackbar>=< Rustys trackbar - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > JKS front trackbar>=< Rustys trackbar
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 06-15-2006, 07:55 PM   #1
gunthagunth
Just wondering which trackbar is better. I ordered the JKS thru Kolak, and i bought a rustys trackbar with drop bracket a month ago and he just decided to ship it because paypal froze his account. Im just wondering which one i should sell. Im leaning towards selling rustys because i already run jks rear and im happy with it but rustys comes with the bracket and i think a different joint. any input is greatly appreciated. Thanks ~Jason
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Claytons/JKS Control arms out back/Addco's/RE brake lines/35"TSL SSR's on 5.9rims/Currie steering/K&N/JKS rear trackbar/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/D30lockrite D44a
gunthagunth is offline   Reply With Quote
Old 06-15-2006, 08:06 PM   #2
zjjeeper
JKS, is far superior to the rustys bar..
anyone recommending rustys over JKS is...
1997 ZJ, knobby tires and stuff..
zjjeeper is offline   Reply With Quote
Old 06-15-2006, 08:17 PM   #3
anticrombie
JKS is just about the most beef thing I have ever seen. I'd recomend this over anything, because nothing can come close to this one!
anticrombie is offline   Reply With Quote
Old 06-15-2006, 08:31 PM   #4
gunthagunth
is it necessary or feasable to use kevins bracket he has for the jks trackbar, i dont know if it uses a different bushing or end. I just want this trackbar to be stable and stout against DW.
Old 06-15-2006, 08:37 PM   #5
anticrombie
I mean you can use it if you'd like...the bracket enables you to use the rear JKS trackbar up front or something like that....
I'd just get the JKS front and rear trackbars from Kolak and call it a day.
Old 06-15-2006, 08:45 PM   #6
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Sell or return the Rusty's bar AND bracket.
I think you are asking if you can use the ZJ JKS bar with Kevin's bracket, the answer is no. The KOR track-bar conversion has a horizontal mount (like the WJ) of the bushing at the uni-body end. The stock ZJ (and XJ and TJ) have the vertical mount.
Kevin has a JKS bar made to fit his trackbar conversion. I highly recommend it.
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Old 06-20-2006, 03:29 PM   #7
gunthagunth
Both trackbars arrived today. Kolaks part came packaged neat and clean from jks and my private sellers package had to be shaken up to see if the rats had already left thru their hole. I have to say I am sticking with the JKS. The bushings are pure beef and i can grease the bushings easier than the rustys. Im not a fan of the heim setup on the rustys. looks like it could get noisy with no grease fittings. The weight difference is pretty big. rustys might have more beef. Rustys bar weighed 12lbs with no bracket while JKS weighed 9lbs. They have the same outer diameter but i think rustys puts a bit more beef into his inner. They are both great looking trackbars and if i was worried about bending the trackbar i would go with the rustys but im going for ride comfort as well as beef so i will be sticking with JKS.
Old 06-20-2006, 03:42 PM   #8
Varkyl
No where near stock
Varkyl's Avatar
That bracket that Rusty's looks rather limp to say the least. And the heim doesn't look like a quality unit either.
Stick with the JKS and you will be happy.
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline   Reply With Quote
Old 06-20-2006, 04:15 PM   #9
Nick ZJ
Heavy does not always mean stronger. Ive hammered the JKS into rocks and such and I have yet to see any signs of it giving in. Its made of some sort of heavy grade material. You will be very impressed with it.
93 zj/4.0/aw4/300/44/70
This is the classic "Unstoppable Force" versus "Immoveable Object" debate. The result? Destruction of the Universe.
last time i tried fording a river 2 of my oxen died and i got dysentary
Nick ZJ is offline   Reply With Quote
Old 06-20-2006, 09:30 PM   #10
gunthagunth
well i think i broke my thumb again installing my rear trackbar but other than my damn rear trackbar bracket welding itself with rust and about a hour and a half to get it off im very happy with them. It took the loose clunking feeling when hitting bumps on the highway. The front end felt like it was going to fall out . Im getting a new exhaust in the next 2 weeks so i will be fixing this but the rear trackbar rubs like hell on my exhaust pipe
Old 06-20-2006, 09:36 PM   #11
anticrombie
You talkin bout that T55 bolt?
Old 06-20-2006, 09:41 PM   #12
gunthagunth
i broke my only t55 socket with my damn breaker bar. so i used a allen socket that fit and threw the air hammer on it. still no go so i tried to drill it out, no go, grinded the head off still no go. beat the hell out of it with the BFH i could see the outline of the stud but when i tried to poke it thru with a hammer and lineup tool it wouldnt budge. I took the air hammer to it still no go. i had to tear the ******* bracket off with a crowbar, air hammer, sawzall and weld the biotch back on.
Old 06-20-2006, 09:47 PM   #13
anticrombie
Wow....That sucks. I just cut the head off, took off the control arm, then hammered the nut and bolt out the back. Then I used a grade 8 bolt and nut and stuff to put it back on. Only problem is I have to take the CA off everytime I have to take off my trackbar, but oh well.
Glock Forum
