Jk ring gear? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Jk ring gear?
Old Man Emu WK Lift - Black Friday Special!!The Original 3/8" Ruffstuff Diff Cover!Safety Thimble Fairleads
Unread 06-18-2014, 06:43 PM   #1
Dubfire98
Jk ring gear?
So in my search for the d44hd 4.56 ring and pinion and coming up on a waiting list, in being told that I can take a jeep jk's gear and just drill out my carrier holes to accommodate the bigger bolts. Now with this being said would I need to swap yokes and use the jk's pinion seal? I'm hurting for these gears in a hurry and I would love to have a way around the wait.
TN JEEPER
Dubfire98 is offline   Reply With Quote Quick reply to this message
Unread 06-18-2014, 07:59 PM   #2
Dubfire98
Bumpity
TN JEEPER
Unread 06-19-2014, 04:56 AM   #3
Dubfire98
Anyone?
TN JEEPER
Unread 06-19-2014, 05:45 AM   #4
Myusername1674
Myusername1674's Avatar
Never heard of this before, i'm far from a gear expert but it does seam a little unlikely
Sent from somewhere besides my computer
95 FiveTwo ZJ, DD, Lifted, Locked on 35s, Build (in progress)
My 5.9 swap (in progress)
Want your zj to be doorless in 60 seconds?
Myusername1674 is offline   Reply With Quote Quick reply to this message
Unread 06-19-2014, 07:09 AM   #5
Kolak
Vendor
Kolak's Avatar
The JK D44 gears will fit the ZJ D44HD housing. You get the benefit of the larger 8.9" ring gear. You will have to drill out the carrier since the JK uses 7/16 or 1/2" ring gear bolts. The kits I sell come with a replacement yoke, since that's different as well to match up with the JK pinion.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is online now   Reply With Quote Quick reply to this message
Unread 06-19-2014, 08:09 AM   #6
Taz360ZJ
VERY interesting info, I'll keep that in my notes!
Slate 5.9 Limited: 8", 231, 8.8, 5 SPD & blower awaiting
Stone white 5.9 Limited: 30's, 231, ECE's
Taz360ZJ is offline   Reply With Quote Quick reply to this message
Unread 06-19-2014, 09:37 AM   #7
CatSplat
Derp.
CatSplat's Avatar
1994 ZJ
Wow, I had no idea that was an option. As JK gears tend to be cheaper than D44A due to economies of scale, how does the price for your conversion kit compare to a regular set of D44A gears, in say 4.56s?
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline   Reply With Quote Quick reply to this message
Unread 06-19-2014, 10:13 AM   #8
Timo_90xj
Timo_90xj's Avatar
I had heard rumours of this, but no concrete facts. It's been said of both the D44a (D44HD) and the "new" D44 rear on the JKs that they are close to D60 strength regarding R&P. I do know the D44a and the new iron D44 both have significantly thicker pinions than the standard D44 does.
IIRC JK D44 has a 32 spline flange yoke and uses 1330 u-joints? The 32-spline pinion wouldn't hurt with the 5.9 torque
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is online now   Reply With Quote Quick reply to this message
Unread 06-21-2014, 09:22 AM   #9
riot1987
Professional Wise Guy
riot1987's Avatar
My buddy was saying something about swapping axle gears out of JK's
I guess its true!! Thats awesome
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
Build thread^^
riot1987 is offline   Reply With Quote Quick reply to this message
Unread 06-21-2014, 02:22 PM   #10
GalarneauWilliam
I would think that would be a PITA I believe the ring gear will be hardened, but I am no expert.
My 97 ZJ Build
http://www.jeepforum.com/forum/f13/9...build-2174217/
GalarneauWilliam is offline   Reply With Quote Quick reply to this message
Unread 06-21-2014, 04:12 PM   #11
CatSplat
Derp.
CatSplat's Avatar
1994 ZJ
You're not drilling out the hardened ring gear, you're drilling out the D44A carrier so you can thread through the larger bolts used to secure the JK44 ring gear.
The Jeep of Theseus
Unread 06-21-2014, 04:30 PM   #12
GalarneauWilliam
Oh that makes more sense.
My 97 ZJ Build
Unread 10-30-2014, 09:04 AM   #13
Dubfire98
Ive finally got everything for this swap. Although the master overhaul kit i got came with OEM zj ring bolts and not the jk but thats an easy fix. Even got a crush sleeve for the jk pinion as well with the kit that came from Kolak. Im hoping the pinion bearings are the same size to match the housing on the zj. Ill be attempting the swap in the coming weekend or so and ill post any problems and the results when im done just so you guys can get an idea of whats involved.
TN JEEPER
Unread 10-30-2014, 12:05 PM   #14
riot1987
riot1987's Avatar
Good luck man! Im excited to see this
Build thread^^
Unread 10-31-2014, 03:24 PM   #15
Dubfire98
one thing I noticed by looking at my parts the JK ring gear has 20, 7/16" bolts. I'm trying to figure out if that's right? My master kit only has 10 new bolts. Is the zj carrier gonna accept the jk ring gear? I realize I need to enlarge the carrier holes but do I need to drill the extra holes too? Kolak can you enlighten me?
