JK Axles into WJ Now Available at IROR
#61 | |
I ate what?
Thanks for stopping by and explaining everything, all I knew is that if you guys sold them they had been throughly researched and would work great
Ken 99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 33" Yokohama Mud Rovers 2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Falken 912's (13.76 @ 103.85) 2006 Pontiac G6 GTP - (her's) 2001 Dodge Ram 1500 - CAI, Soft 8's, 31's 2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch 2006 Triumph America 900 - Full Dresser January 2009 Grand Cherokee of the Month (GCOTM)
#62 |
semper fi
hmmmmm, this has got me wondering......if i went ahead and swapped to these axles, to the new high clearance arms....what would i have to swap out my 5.5 inch springs for to clear 35's on my dub.....hmmmm
-2002 Grand Cherokee Overland 4.7 HO, 5.5 IRO w/adj. LA's & quick discos, Bilstein 5150 remote res, Addco front and rear, K&N intake, 33x12.5 dik cepek F-CII(dd setup), 32x11 bighorns(wheeling setup) -2003 wrangler, 4.0 liter, manual transmission, cd player, sound and light bar, subs, 6 inch lift, 33x12.50 -2005 wk 4.7.....waiting to install 4 inch superlift |
#63 |
I ate what?
Just some fender trimming and you will be golden, that's my plan anyway.
#64 |
Whats is the caster with the drive shaft aligned at 5.5" on the JK axle ?
Nickerdoodle 03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's 35" BFGoodrich KM2 sira4x4.net North East Offroad Club www.carolinadriveline.com www.ironrockoffroad.com kolak@aol.com |
#65 |
semper fi
hmmmmm, i bet while they are swapping the rest of the parts they would have no problem throwing 6.5 inch springs in place of my 5.5's. i bet that would free up a bit more space
#66 |
Addicted to Boost.
Trimming is your friend... keep a low COG!
2007 VW GTI |
#67 |
I ate what?
I agree, I think any taller than 5.5" is going to bring more issues I don't want to deal with. Not to mention that anywhere I've wanted to go, I wasn't limited by the lift height at 5.5"
#68 |
Should be fine with trimmage and 35's...but for 37's think you need to move to 6.5" coils to accomodate for the necessary bump stops. Only so much you can trim.
#69 |
Addicted to Boost.
H3 ran 37's on 6" coils before he sold his rig.
2007 VW GTI |
#70 |
They were RK 6.5" coils that measure closer to 7" - and thats still 1" extra of bump stop.
#71 |
Are the 4.10 gears it comes with ok for 35" or 37" tires or will you need to regear?
04 WJ freedom edition, Iro 4" LA lift with MX 6 shocks, JKS Quik disco's, Tom Woods DS, Addco sway bars, Iro skid, spidertrax wheel spacers, 265/70/17 Maxxis Bighorns, K&N cold air intake |
#72 |
Tires
It will work with 33" if you go bigger you will want to regear.
Will 99 4.0 DubJ 35MTRs ford 9" The Hookup http://www.mallcrawlin.com/forum/showthread.php?t=12701 |
#73 | ||
zj tractor
if you have a V8 for 35"s.....4:56 gears for 37''s....4:88 gears if you have a I6 for 35''s....4:88 gears for 37''s....5:13 gears
hard working private first class in the United States Marine Corps. Quote:
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/ |
#74 |
Quote
Here is what the FAQ from the JK forum says about gears and tire size. Granted they weigh less.
33" tires 3/4" spacer lift front minimum (2" BB preferred) no gear replacement needed, 4.10's preferred. 34-35" tires minimum 2.5" BB/3" lift, will rub at full flex with 2.5BB trim/remove front air dam new gears may be needed on automatic transmissions, overdrive not able to be used (possible upgrade to 4.88's or 5.13's but not necessary) 4.10's ok for manual, but 6th gear obsolete. trim pinch weld at rear tire 36-37" tires minimum 3.5-4" lift some trimming may be required on front bumper/fenderwells new gears 4.88 or 5.13's (4.10s will be insufficeient for both manual and auto) trim pinch weld at rear tire
#75 |
You could definately run 35's on 4.10's with the V8, assuming you're not getting a super heavy set (ie Toyo MT's that are 35x13.5 and near 85lbs each) Even so I think you'd be ok. I'm running 285/75R16's and with the V8 + 3.73's power is adequate.
4.10's would not be ideal but IMO you can run a 315/75 tire without a prob. After rethinking things, if you have a V8 this axle would be pretty perfect if you don't plan on going bigger than 35's, which for streetability, you probably don't want to. For the I6, it would be interesting with 35's and 4.10's.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
