JGC 97 motor idle problem - JeepForum.com
post #1 of 15 Old 11-10-2005, 02:51 PM Thread Starter
elvisdk
Hey from Denmark.
I have a problem with my jeep. Maybe its a small problem, hope so..
Here is the problem:
The engine starts fine, runs half a mile or so, then i brake or release the speeder, and then the engine shuts down. (the rpm drops rapidly)
I can start it again after a few minutes, with problems though. It takes around 10--15 seconds for the ignition to start the motor. And when i drive again, the same problem occours.
Do you have a clue on what might be the problem ?
There is oil in the system
The battery is ok
me want cheaper gaz for my jeep
elvisdk is offline
post #2 of 15 Old 11-10-2005, 05:36 PM
Silver yj
Could be several things, fuel filter clogged and not getting enough pressure to the engine, bad converter, vacume leak...... Do you a check engine light on?
Silver yj is offline
post #3 of 15 Old 11-11-2005, 01:36 AM Thread Starter
elvisdk
The Check Engine lamp turns off when the motor is running.
Standard procedure i guess.
Can i change the fuel filter myself ?
elvisdk is offline
post #4 of 15 Old 11-11-2005, 06:21 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
What engine do you have?
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #5 of 15 Old 11-11-2005, 06:31 AM Thread Starter
elvisdk
4.0 Laredo
The dealer said it might be the "idle motor" had to be reset ?
elvisdk is offline
post #6 of 15 Old 11-11-2005, 06:39 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I would get a can of Throttle body cleaner from the dealer first and follow the directions on the can. If that doesn't help, then try something else. The can is only 8 or so dollars American. I'm not sure what the exchange rate is right now.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 15 Old 11-11-2005, 07:11 AM
guango88
Air Trans
guango88's Avatar
maybe is just a bad censor! Do you know anybody that has a code reader OBDII, get some codes! some times the engine light doesn't come on for certain things
ONE ABOVE ALL
guango88 is offline
post #8 of 15 Old 11-11-2005, 07:53 AM Thread Starter
elvisdk
What does the Throttle body cleaner do ? Does it go into the gastank ?
Just so i can get an understanding on what i have to look for at the local dealer.
I dont know anyone who have a code reader
Just for fun, ill try to change the battery tomorrow maybe.
elvisdk is offline
post #9 of 15 Old 11-11-2005, 08:22 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Go to an auto parts store like checker and they most likely have one you can use.
Buy the Mopar Throttle Bottle Cleaner at the dealer and just read the instructions on the bottle. Use the entire bottle..
-Ryan
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #10 of 15 Old 11-11-2005, 08:55 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Ryan,
let's do a search for Checker auto parts in Denmark...............
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #11 of 15 Old 11-11-2005, 09:11 AM
ArloGuthroJeep
Mr. Hyde!
Originally Posted by www.google.com
Results 1 - 10 of about 95,000 for Checker Auto Parts Denmark. (0.22 seconds)
Whats your point? So what if none of them are relevant
You have picked on me enough, it's Phil's turn
post #12 of 15 Old 11-12-2005, 09:03 AM Thread Starter
elvisdk
I have further checked the engine and found out the cooling system is leaking water.
So maybe theres no pressure in the water system.
Does that have effect on the motor idling ? Maybe the car computersystem crashes if the thermostat cant register any water ?
elvisdk is offline
post #13 of 15 Old 11-12-2005, 09:49 AM Thread Starter
elvisdk
Found this in the haynes manual for the car :
11. Engine coolant temperature sensor.
The engine coolant temperature sensor
senses engine coolant temperature. The
PCM usess this information to control fuel
delivery and ignition timing
Chapter 6-4 Emissions and engine control systems
The book is called
Jeep Grand Cherokee
1993 thru 2000, all models
Haynes repair manual
elvisdk is offline
post #14 of 15 Old 11-14-2005, 10:48 PM
kentman
kentman's Avatar
2006 XK Commander
I like the fuel filter, or better yet, the fuel pump. If it is about to die, then it will give you a CEL and kill the engine. You should have the pressure at the fuel rail tested to see if it is normal.
Also, I encourage taking off the IAC motor and cleaning it thoroughly. I did that recently with throttle body cleaner, and it fixed my high idle problems.
'06 XK Limited, 5.7L, QD II, Black, 170K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 130K
kentman is offline
post #15 of 15 Old 11-19-2005, 09:08 AM Thread Starter
elvisdk
Hey again
It turned out to be the cooler.
So maybe it was the thermostat had an effect on the rpm's in idle mode.
Weird
Thanks for the help
elvisdk is offline
Bucking, Sputtering, Wierd idle IAC motor, TPS, Im stumped?? jlcca844 ZJ Grand Cherokee Forum 42 09-30-2011 04:36 PM
Idle Air COntrol Motor kopite77 ZJ Grand Cherokee Forum 48 12-22-2009 10:13 PM
Vibrations at Idle / Motor Mounts befumo ZJ Grand Cherokee Forum 7 11-08-2009 07:56 PM
idle air control motor gasket?? the88thpianoman ZJ Grand Cherokee Forum 5 08-07-2008 06:27 AM
idle air control motor choppy ZJ Grand Cherokee Forum 1 05-18-2006 02:21 PM
