jeepdaddyo - JeepForum.com
post #1 of 10 Old 07-06-2006, 09:45 AM Thread Starter
jeepdaddyo
jeepdaddyo
help 95 grand cherokee wont start, it was running fine untill last time daughter turned it off. i have replaced cap, rotar. pick up coil, plugs , fuel filter, plug wires,battery cable ends and crank position sensor. have 40lbs of fuel pressure while motor is cranking and nice blue spark don,t think its the alarm because in the past when it was the alarm it would start and then die , no it just won, start, also have switched the auto shut off relay with simular ones in fuse block.
jeepdaddyo is offline
post #2 of 10 Old 07-06-2006, 09:47 AM
Razor.
Razor.'s Avatar
You should try posting this in the Grand Cherokee Forum.
Razor. is offline
post #3 of 10 Old 07-06-2006, 09:47 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
This post --> GC board.
If its a 4.0l, check the cam postion sensor.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 10 Old 07-06-2006, 10:07 AM Thread Starter
jeepdaddyo
jeep daddyo
I was told by dealer it uses the pick up coil instead of cam position sensor o it is a 4.0
post #5 of 10 Old 07-06-2006, 10:09 AM
nierace
nierace's Avatar
2003 WJ
Hehe bet you wish you could delete that comment = )
nierace is offline
post #6 of 10 Old 07-06-2006, 10:15 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
It was originally in the Wagoneer forum...Now I bet you wish you could delete that comment
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #7 of 10 Old 07-06-2006, 10:16 AM
nierace
nierace's Avatar
2003 WJ
Ohh thats not fair. Dirty.
nierace is offline
post #8 of 10 Old 07-06-2006, 10:24 AM
Varkyl
No where near stock
Varkyl's Avatar
I would talk to them about that again.
Because if you are getting everything as described the only thing left is that the injectors aren't pulsing.
Have you pulled a plug to see if it is wet with fuel?
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline
post #9 of 10 Old 07-06-2006, 10:48 AM Thread Starter
jeepdaddyo
plugs are wet checked voltage at injectors had 7 volts when key was turned to on and 12.6volts while cranking.
post #10 of 10 Old 07-06-2006, 10:50 AM
ArloGuthroJeep
Mr. Hyde!
Try jumping your Jeep while starting it. If that works then your battery is kaput...
