Jeep zj lift - JeepForum.com
post #1 of 37 Old 04-14-2013, 09:26 PM Thread Starter
ryanfuscozj
Jeep zj lift
I have a 96 4.0 zj and I wanted to put a 4-5" lift on it, what's the best but cheapest way to do so? Also I wanted to keep my stock rims so what is the biggest tire I can use with that size lift and on stock rim?
ryanfuscozj is offline
post #2 of 37 Old 04-14-2013, 09:29 PM
WhiteOut
WhiteOut's Avatar
Cheapest for a good, correct 4"-5" lift is going to be around $1000.
On a stock 7" wide rim I'd go up to an 11.5" wide tire
WhiteOut is offline
post #3 of 37 Old 04-14-2013, 09:43 PM Thread Starter
ryanfuscozj
I found an Old Man Emu lift kit on their website for around $560, would that not be a good investment if it's only that much money? 11.5" wide, so how tall could I get it? 33s?
post #4 of 37 Old 04-14-2013, 10:08 PM
AmishFury
the thing about lift kits... you may see these small prices on the kit that are well below what people here tend to say... because the kit generally includes just enough components to make the jeep sit taller... driving with the lift is another story
usually all manner of little things that add up quickly and turn a $560 kit into a $1000+ job
AmishFury is offline
post #5 of 37 Old 04-14-2013, 10:29 PM
BigRedB
1993 XJ Cherokee
Going cheap is not generally always the best choice when purchasing lift kits, maybe for a 2"- 3" lift. But for 4"- 5" I would not go with cheap. If your looking for a good one that is.
BigRedB is offline
post #6 of 37 Old 04-14-2013, 10:44 PM
PolkaPower
The tallest lift OME makes for a ZJ is 2.5". You have a lot to read.
PolkaPower is offline
post #7 of 37 Old 04-14-2013, 10:47 PM
dnuccio
doing it right gets expensive fast, set aside at least a grand for the lift.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #8 of 37 Old 04-15-2013, 12:10 AM
ksturgio
When I bought my first lift for my zj I bought the most expensive one I could afford for $672.00. It didn't come with CA's or extended brake lines and real stiff springs. At the time it was my DD but I also had a motor cycle. What I ended up with was DW you couldn't believe. I was running a 4.5 lift on stock arms with worn out bushings and I turned my sweet zj into a death trap.
So instead of buying one good lift for $1000-1500 I spent $2200 on fixing the first lift.
ksturgio is offline
post #9 of 37 Old 04-15-2013, 05:13 AM Thread Starter
ryanfuscozj
I'm on a tight budget, so I'll probably just do a 2-3" lift, what would be the best kit to do that with?
post #10 of 37 Old 04-15-2013, 05:20 AM
Jerbear0612
Just stick with a 2"bb and new shocks
Jerbear0612 is offline
post #11 of 37 Old 04-15-2013, 05:59 AM Thread Starter
ryanfuscozj
I found a 3" suspension lift on ebay, I shouldn't do that?
post #12 of 37 Old 04-15-2013, 09:57 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Which kit is it? If it is fat Bob's, just say no.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #13 of 37 Old 04-15-2013, 10:05 AM Thread Starter
ryanfuscozj
post #14 of 37 Old 04-15-2013, 10:07 AM
PolkaPower
No. You will need adjustable track bars and those shocks are guaranteed to suck. Get it if you don't care how it rides. A 2" BB with some nice shocks will fit 31's and still ride nice.
post #15 of 37 Old 04-15-2013, 10:16 AM
JohnnyZJ
2" BB
thats about all you can do without dropping a few Gs. edit: if you want it to ride similar to stock and not feel dangerous
if you've never done this before, and are guaging your prices on what you 'think' stuff will cost, double your initial budget.
lifting these things is not cheap. never has been; never will be.
07' JKUR rollin on 35s
JohnnyZJ is offline
jeep , lift , rims , tires , zj
