Jeep ZJ Front Winch Bumper Build - JeepForum.com
post #1 of 25 Old 02-15-2012, 06:36 PM Thread Starter
burky45
Well Ive started making my new winch bumper i will update day by day of my progress so stay tuned
Day One:
Today popped my bumper cover off and stripped it down to the main Steel Bumper but spent over 3 hours trying to get these black brackets off my frame no idea what they were for but they were in the way and they had to go
burky45 is offline
post #2 of 25 Old 02-15-2012, 06:44 PM
SAR-Swimmer
If I'm not mistaken, those look like part of the mounting system for front tow-hooks.
SAR-Swimmer is offline
post #3 of 25 Old 02-15-2012, 07:06 PM
KingtheZJ
yes. for the factory tow hooks
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #4 of 25 Old 02-15-2012, 07:23 PM Thread Starter
burky45
Yes thats what i thought but i left the other mounts for the tow hooks on because they were a pain to remove and i intend to make use of them down the road
burky45 is offline
post #5 of 25 Old 02-16-2012, 06:06 PM Thread Starter
burky45
Day Two
Today i notched out the oval holes in the bumper and cut some channel iron and drilled the holes and those will be the main bumper suppourt i also cut off the rubber inside my wheel well
burky45 is offline
post #6 of 25 Old 02-16-2012, 09:54 PM
TMNT2210
Looks good so far man- keep up the work. You have my attention cause i just finished a project that was a lot like this that you are about to begin. I did a day for day thread like you are doing for yours. check out mine, let me know if you have any questions. The best piece of advice i got was to put a plate on the outside of the frame where you bolt to your holes that you torched out. That way he makes like a 'sandwich' type hold on to the frame and will give it more support. here is the link to my thread- keep up the good work bro.
http://www.jeepforum.com/forum/f13/b...month-1318446/
Dereck
If you don't know what a ZJ is- you can't afford it! -Beerfest
"cowabunga!!!" -TMNT
TMNT2210 is offline
post #7 of 25 Old 02-17-2012, 06:43 AM Thread Starter
burky45
Thanks I actually am using a couple ideas that you used but I'm stuck at how far my bumper should come out? Well the braces anyways and I'd like to fit a 10,000 lb winch and have a bit room left to play with
burky45 is offline
post #8 of 25 Old 02-17-2012, 08:01 AM
TMNT2210
Yea- use cardboard and ducktape to get a template and just keep cutting. But that is the main reason i just put a hitch up there for my winch, that, and so i can have it universal (rear and front). I have a 10,000 Warn winch and it felt to heavy to leave up there full time, for gas reasons.
Dereck
TMNT2210 is offline
post #9 of 25 Old 02-17-2012, 11:14 PM Thread Starter
burky45
Day Three
No progress today but i did go and pick up a 4 x 8 sheet of 10 ga steel from a local metal shop and i have 1/4 for the more heavy duty spots
burky45 is offline
post #10 of 25 Old 02-24-2012, 01:23 PM Thread Starter
burky45
Day Four
Got some cardboard and duct tape and made a cardboard template for my new bumper, scale was off a bit but i just needed a general idea of what to do
burky45 is offline
post #11 of 25 Old 02-24-2012, 01:25 PM Thread Starter
burky45
Day Five
I did some general "Clean Up" Of my mount slots and these are the hook mounts i was talking about that i decided to leave on
burky45 is offline
post #12 of 25 Old 02-24-2012, 01:30 PM Thread Starter
burky45
Day Six
I had a scrap sheet of 1/4 inch steel so i decided to use it, im going to use 1/4 where the winch will mount and another pieace where the fairlead will mount also two on the inside sides of my winch pocket other than those spots im using 10 ga steel. I also tack welded the nuts to my mounts and cut them down so that my bumper will sit 9" off the front of my jeep
burky45 is offline
post #13 of 25 Old 02-28-2012, 09:15 AM
TMNT2210
Looking good man. Keep it up.
Dereck
TMNT2210 is offline
post #14 of 25 Old 03-03-2012, 07:50 PM Thread Starter
burky45
I need a hand ...
I'm having trouble lining up my holes for my mounts so I made new ones that will bolt directly to the face of my bumper and I will sandwich it with anothe plate on the back side is the bumper face metal strong enough to withstand a 10000 lb winch? Even if sandwiched?
burky45 is offline
post #15 of 25 Old 03-05-2012, 10:00 AM
Midnightluckey
Originally Posted by burky45
I need a hand ...
Like the factory front metal crossmember? No. You could get away with mounting a non-winch bumper there however.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
My front tow point/ winch subframe build *pics* pulsepb ZJ Grand Cherokee Forum 23 12-08-2011 07:58 PM
Winch in Stock front bumper speeddemon651 WK Grand Cherokee & XK Commander Forum 16 11-09-2011 07:04 PM
Front Bumper Build Inavacuum ZJ Grand Cherokee Forum 7 11-02-2011 04:40 PM
ZJ front winch bumper build RRAM ZJ Grand Cherokee Forum 25 03-05-2010 09:59 PM
ZJ front winch bumper? greggradwohl ZJ Grand Cherokee Forum 4 01-29-2007 03:50 PM
