Jeep ZJ ABS Light on, ABS not functional - JeepForum.com
post #1 of 74 Old 11-14-2008, 04:27 PM Thread Starter
compcrasher86
Hey everybody, this is my first Jeep so Im still getting used to it. The ABS light is on and somebody told me if the light was on the system was off. Sure enough I went into a parking lot, layed on the brakes, and the wheels just locked up, no ABS. Where should I look/what should I do first to get it working again?
Its a 97 Grand Cherokee 4wd, 4L Straight 6
Im a big carhead so I dont mind taking parts of it apart, heck, thats why we buy jeeps right?
compcrasher86 is offline
post #2 of 74 Old 11-14-2008, 04:41 PM
elmer_fud
I would start by checking the fuses, and checking the wheel speed sensors. maybe one of the sensors wiggles loose.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #3 of 74 Old 11-14-2008, 04:46 PM
dxmedia
Take a resistance reading from each sensor on the wheels, the odd one out will need replacing. If they are all the same then it's going to be a broken wire / or a faulty abs ECU.
My money is on either one of the front wires being broken with someone taking off the hub and pulling the wire or a faluty sensor.
I've not had a good look at a jeep, so talking about cars in general.
dxmedia is offline
post #4 of 74 Old 11-14-2008, 05:01 PM Thread Starter
compcrasher86
I checked three fuses, two were big maxi fuses next to the battery (ABS Valve and ABS Pump) and the third was a small maxi fuse in the passenger side under dash. All of them were intact and good. Its too dark/Late to be taking off tires tonight so Im going to have to wait until tomorrow to do that
post #5 of 74 Old 11-14-2008, 07:40 PM
jabsther
2010 JK Wrangler
Recheck the small fuse in the passenger side again. I had the same problem and all the fuses were good. Cleaned the contact posts on the fuse and it has worked great for years now.
jabsther is offline
post #6 of 74 Old 11-14-2008, 11:13 PM Thread Starter
compcrasher86
jabsther I wish it was that easy. I checked the fuse, scraped the posts down a little bit (they were quite dirty!) and cleaned with electrical contact cleaner. Put it back, turned the key, crossed my fingers. and the light still stayed on. Guess Im checking the sensors tomorrow... can I get at them without taking the wheels off? it would probably make my day a fair amount easier.
post #7 of 74 Old 11-14-2008, 11:57 PM
elmer_fud
yes. If you look behind the brake, there is a tone ring ( a ring with lots of teeth on it). By this ring there should be a black plastic thing and this is the sensor.
Brian
post #8 of 74 Old 11-15-2008, 06:24 AM
newfieZJ
The first thing I would do , is disconnect the ABS from it`s control module on the d/s fender well . Check for ANY corrosion , the , on the female side , using a small pointed screw driver , close each inlet so the male end gets a better connection , there`s a few . Use some dielctric grease and snap it back together .
This worked for a friend after he was quoted $2500 for the repairs , no problems for a yr now . Oh , btw , he had a 97 like yours !
Cost was ZERO , if you have the grease , so worth trying
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #9 of 74 Old 11-15-2008, 08:27 AM Thread Starter
compcrasher86
yes I have the grease and boy oh boy is there some corrosion spots around the engine, (grandma liked to drive her through big big puddles) so I wouldnt doubt it hitting the abs controller. Last nigh I disconnected the ABS Sensor cables under the rear seat in the car and tested the OHM between the two wires. (That theoretically should work right?) Anyways, both were reading around 9,000OHM (Im using my new digital one today) so I assume those two are fine?
post #10 of 74 Old 11-15-2008, 08:39 AM Thread Starter
compcrasher86
Okay Im still having troubles finding the control unit. My buddy tells me that the 1997-1998 dont use an ECU, but in fact a Hydraulic Control Unit (HCU) mounted near the CAB or something. I still dont see it.....
post #11 of 74 Old 11-15-2008, 08:58 AM
newfieZJ
he`s right , it`s called a HCU , an all in one unit . It`s got to be all in the same area , d/s fender/firewall area . Still looking till someone chimes in
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #12 of 74 Old 11-15-2008, 09:01 AM
newfieZJ
Remove neg battery terminal
remove air cleaner assembly
remove windsheild washer bottle
this should give you access to the HCU plug in
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #13 of 74 Old 11-15-2008, 10:01 AM Thread Starter
compcrasher86
Alright, I think I found it, There were two plugs going into it, one with many wires and contacts, and then one with two thicker wires that appeared to power what looks like the pump. I cleaned it (wasnt really dirty to start with but whatever) and plugged the connnector back in, and tried turning the key... no luck.
I also traced the wires from the front speed sensors up into the engine compartment and I found little connectors inline, where I was able to measure the resistance. So with my new digital multimeter, heres the readings I am getting. FL=1,077; FR=1,070; RL=1,049; RR=1,063. They all seem fairly close so I am guessing the speed sensors are not the problem, unless they all are failed and I have trouble beleiving that.
Also, now that I know where the ABS controller/Pump is, I was able to listen to it. I had my brother turn the key to "On" and I listened. From that area, (pretty sure it was coming from the pump), I heard a faint buzzing sound for a second. Then it stopped, clicked a couple times, and then nothing.
Heres a photobucket album of today's work: http://s45.photobucket.com/albums/f8.../Fixing%20ABS/
I wish I could post img tags but I cant yet, have to wait till 25 posts, sorry
post #14 of 74 Old 11-15-2008, 10:07 AM
-Joe-
-Joe-'s Avatar
I know it probably would not be free but why not just have someone check the abs codes and forget the random checking?
I wonder what the dealer would charge for the diagnostic
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #15 of 74 Old 11-15-2008, 10:16 AM
newfieZJ
you should also know that tha ABS WILL NOT CLEAR MEMORY by disco`ing the battery , but will after 50 starts or cleared by a code reader , most likely a dealer job .
1995 Orvis build
1988 MJ build
newfieZJ is offline
1997 zj non infinity tweeter wires functional? benspilk09 ZJ Grand Cherokee Forum 2 02-05-2009 07:19 PM
Erratic Idle + Not functional Cruise (intermittent problem) mz3bo ZJ Grand Cherokee Forum 11 05-21-2007 10:50 PM
Check engine light on. Jeep Off. skidmark421 ZJ Grand Cherokee Forum 1 03-02-2007 04:53 AM
Built myself a multi-functional trunk box...Check it out! (>56k suggested) wino_ii ZJ Grand Cherokee Forum 5 03-25-2006 12:55 PM
AX-15 conversion is functional! Woody ZJ Grand Cherokee Forum 24 01-16-2006 09:16 PM
