jeep wont start without a jump and cant hold an idle when started - JeepForum.com
post #1 of 12 Old 07-04-2007, 10:20 AM Thread Starter
XJ99RedNY
ok so i have a 97 zj 4.0 and when i try to start it the lights dim and it clicks but wont even turn over. i tried starting in neu with no luck, i tried hitting the starter with no luck... im thinking one of three things bad battery(highly unlikely since i have a year old optima yellow top in it) bad alt, or some kinda short/bad ground. i have a jumper pack, and when i connect it to the battery all the lights go back to full strength and she starts right up, but if i dont keep giving it gas it dies... any ideas? i need this for work in the morning tomorrow.... but im thinking i may be screwed lol
97 ZJ---
2 Inch Skyjacker bb
K&N SRI
Gibson Catback exhaust
XJ99RedNY is offline
post #2 of 12 Old 07-04-2007, 11:27 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Battery cable ends - about 3 bones at your local auto parts store. Chop off the end, strip it back a bit, screw on the replacement.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #3 of 12 Old 07-04-2007, 12:19 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Sounds like a bad battery to me!
What is the battery voltage when it is running and not running?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 12 Old 07-04-2007, 12:34 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Yellow tops definitely aren't infallible. Get it tested.
I still think your battery clamps are fried.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #5 of 12 Old 07-04-2007, 01:06 PM
PDCamaro318
This exact thing happened to me about 6 months ago. I also have an Optima Yellow top. I replaced the battery under the Optima 3 year warranty and the Jeep was cranking just fine afterwards. My bet is on your battery.
96 GC|242|I-6|3.5" KOR Lift|32" MTRs|OME SS|HD Tie Rod and Drag Link|16"AR Wheels|KOR's Front TB Conv.|JKS Adj. Rear TB|RE Adj Front LCAs|RE Adj Front UCAs
98 5.9|Addco Front|Uniden PC78 Elite|Wilson 5000 with 5 ft whip|4.5" Clayton Long Arm Lift with 2" BB on top|CRS Front Bumper|242 Conversion| 33" BFGs|
PDCamaro318 is offline
post #6 of 12 Old 07-04-2007, 01:09 PM
SteelBlue_WJ
SteelBlue_WJ's Avatar
I would check the connections. it's summer time that the corrosion really builds up there. get a battery terminal cleaning brush, it's like 1.99 at the auto parts store and try cleaning the battery terminals and all the connection. DONT BREATHE close to this when doing so. I would do this first before replacing anything as it can affect not only battery power, but charging of it as well. either way you will need one of these too. I've helped 4 friends out with "dead batteries" this summer and it was just the contacts.
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline
post #7 of 12 Old 07-04-2007, 09:01 PM
mudgts
mudgts's Avatar
Do you think that the alternator went? which could have caused his battery to die? I had that issue before where I killed an alternator, ran down my battery and had to replace both.
where is the thread on worst stuck Jeep Compass?
mudgts is offline
post #8 of 12 Old 07-04-2007, 09:50 PM
98zjteen
The bad idle could be caused by a bad tps (throttle position sensor) and get the battery tested
98zjteen is offline
post #9 of 12 Old 07-05-2007, 04:02 AM
SnaFu2
Not an expert, but the bad idle is probably coming from the fact that the battery is dead. now with a new battery or charged battery, the computer has to relearn ur settings. happens to me every time the battery is disconnected.
SnaFu2 is offline
post #10 of 12 Old 07-05-2007, 09:49 AM
2007GC Overland
2007 WK
Hi Guys
Something happened to me - the Jeep went into a river, the water got all over the battery. The charge system would not charge or had problems charging - low voltage. I could figure what was going on - cleaned the top of the battery with baking soda, the Jeep starting charging 14+V. Before I cleaned the top of the battery, it looked clean but must have had some minerals from the river there. Maybe be the issue just some information.
thanks
Bill
2007GC Overland is offline
post #11 of 12 Old 07-05-2007, 09:55 AM
95ZJL
95ZJL's Avatar
voltage regulator fried? happened a lot to my old teacher on his jeep sometimes the things go and dont allow a full constant charge .....
The line isn't about the motive, it's merely the result.
1995 ZJ Limited Black/Gold
5.2 V8 NEW 249
2" Doestch 3000 Shocks
31x10.5 BFG All-Terrain's
KOR Radiator Support
95ZJL is offline
post #12 of 12 Old 07-05-2007, 10:47 AM
greasefingers
1994 ZJ
Originally Posted by 2007GC Overland
Hi Guys
Bill
I have learned something today!
Cheers Steve
wont start, stalling, high idle soyomakate ZJ Grand Cherokee Forum 10 01-05-2010 01:37 PM
Please Help Jeep Wont Hold Charge!!?!?!sos peicherokee ZJ Grand Cherokee Forum 26 04-22-2009 12:15 PM
my jeep wont start 04ColumbiaWJ ZJ Grand Cherokee Forum 2 04-14-2009 03:50 PM
Jeep wont start savethehumans ZJ Grand Cherokee Forum 7 01-07-2008 11:17 PM
dead battery, jump started it, then 30min after doesnt idle 94gclimited ZJ Grand Cherokee Forum 1 09-16-2002 03:55 PM
