jeep wont start: windows down stuck outside...explanation inside - JeepForum.com
post #1 of 19 Old 07-09-2011, 08:12 PM Thread Starter
jrollings
Hi everyone. I borrowed my sister in-laws 94 ZJ today. I left her house to go to Lowe's and the windows worked great and the jeep started just fine. Came back out from Lowe's and drove home. When I got home I tried to roll the windows up with no luck (power everything) and then shut the jeep off to run inside. Came back out to put the jeep in the garage to find the jeep wont start and the anti-theft system is activated. The key wont turn to start the jeep yet will turn backwards towards me to allow the accessories to work yet the windows wont roll up, the jeep still wont start and the lights blink with the red security light and horn sounds. I only have the one key being she is on vacation in Minnesota and Im still at home in Indiana. (she took her other keys for some reason) Everytime I go turn hit the unlock button or turn the key in the door to the unlock position to disarm the anti-theft system the horn sounds. Can anyone help me out here ? I really dont want the jeep stuck outside with the windows down in the middle of the driveway. I tried to search but came up with bad ignition switch. I also tried tapping the ignition key into the cylinder with no luck turning the jeep on.
Any help is greatly appreciated.
1998 ZJ 4.0l, 231K, lifted 3.5" 31x10.5r15 Interco
Jason
jrollings is offline
post #2 of 19 Old 07-10-2011, 07:05 AM
Foundrydude
Use a key in the door lock to manually disable the alarm. You may have to use the passenger door, lots of trucks have a busted switch in the driver's door.
Then, put it in park extra hard.
Foundrydude is offline
post #3 of 19 Old 07-10-2011, 07:10 AM Thread Starter
jrollings
Thank you for the input but no luck Foundrydude. I tried passenger door, the rear hatch and the driver's door. When I unlock any door the horn sounds. Any other ideas ?
Jason
post #4 of 19 Old 07-10-2011, 09:58 AM
airwolf9090
I would pull the dang relay for the horn while your trying to figure this out.... Makes your head hurt alot less. lol
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #5 of 19 Old 07-10-2011, 11:16 AM
sskilla
do a search for disabling alarm. you just pop the driver side door panel and short two wires. it will let you get around until you can get to the bottom of the issue.
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #6 of 19 Old 07-10-2011, 12:23 PM Thread Starter
jrollings
I tried disabling the alarm lastnight with no luck. I took the door panel off and found the purple wire with a yellow tracer, jumped the black and purple wire and when I did that the horn would sound again. Also the security light and headlights would flash with the key in the accessory position.
Jason
post #7 of 19 Old 07-10-2011, 01:03 PM
sskilla
did you use the cut and ground method or the wire jumper in the plug method? it you did the jumper method maybe the wire you used is too big/small to get in the connector and make a connection?
if this is done right the alarm is completely bypassed and should be impossible to arm.
sskilla is offline
post #8 of 19 Old 07-10-2011, 01:07 PM Thread Starter
jrollings
alrighty I'll try it again when I get back home
Jason
post #9 of 19 Old 07-10-2011, 02:42 PM Thread Starter
jrollings
tried jumpering the purple wire with the yellow tracer and black wire again to only have the same issue. It may not be making a solid connection but i may end up just cutting and grounding the purple with yellow tracer wire and see where it goes from there. If this doesnt work should I assume (yeah i know what assume means) that the ignition cylinder needs replaced ?
Jason
post #10 of 19 Old 07-10-2011, 04:47 PM Thread Starter
jrollings
Ok I ended up cutting the purple and yellow wire to actually ground it and the anti-theft system so no more anti-theft mode. Jeep's ignition still only turns to the accessory mode and still wont start... any other ideas ?
Jason
post #11 of 19 Old 07-10-2011, 05:43 PM
Mark05059
wiggle the steering column while trying to turn the key forward to start.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #12 of 19 Old 07-10-2011, 05:48 PM
Corrupt
If the steering wheel has adjustable tilt steering, then tilt the steering wheel while trying to turn the key. Don't be a little red riding hood when tilting the steering wheel up and down either.
***If you try to fail and succeed, then which have you done?
***RIP Ratmonkey!!***
Corrupt is offline
post #13 of 19 Old 07-10-2011, 06:45 PM Thread Starter
jrollings
I've tried wiggling the steering wheel while trying to turn the ignition cylinder forward with no luck. I did take the plastics off and unlock the steering column but still cant get the ignition to turn forward by forcefully tilting the steering wheel or wiggling it.
Jason
post #14 of 19 Old 07-10-2011, 07:04 PM
elf517
hot wire it ironically they show you how to do it on a jeep steering colum video at the bottom
elf517 is offline
post #15 of 19 Old 07-10-2011, 07:04 PM
elf517
elf517 is offline
Jeep wont start sometimes MassRedneck ZJ Grand Cherokee Forum 2 02-09-2010 11:22 AM
jeep wont start clane92 ZJ Grand Cherokee Forum 1 12-27-2009 10:01 AM
zj stuck in mudhole. staled and wont start. need help now! TwistedcaB- ZJ Grand Cherokee Forum 35 01-27-2009 10:13 PM
HELP! My Jeep WOnt start coolest_Stan ZJ Grand Cherokee Forum 15 10-18-2005 03:15 PM
Jeep wont start... justinhall ZJ Grand Cherokee Forum 9 09-15-2005 02:10 PM
