Jeep Wont Start! - JeepForum.com
post #1 of 2 Old 05-02-2013, 03:13 PM Thread Starter
TPToups
Jeep Wont Start!
Ok, i have a 1996 Jeep Grand Cherokee. In the mornings it will not start, it will act as if its going to but wont. But as soon as i get home from school it cranks right up. What could be the problem, to where it just don't start in the mornings? I live in Louisiana, so its barely ever cold here, so i dont suppose that would be the problem. I have already replaced the computer system, coil, distributor, rotor, camshaft sensor, crankshaft sensor, starter, and the battery. But yet it continues to do this, but only in the mornings!!
Someone please helppppppp!
Thank You
GO BIG, OR GO HOME!!!
TPToups is offline
post #2 of 2 Old 05-02-2013, 03:45 PM
JasonStebbins
Did you use Mopar brand for all the sensors you replaced? Test fuel pressure at the rail? Sounds like it could be the anti-drainback valve which is part of the fuel pump assembly. It's strange though that it only happens in the mornings.
Battery terminals clean and new? Does it run normal once it starts up?
Poop
JasonStebbins is offline
