Jeep Won't Idle ?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Jeep Won't Idle ??
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 12-03-2002, 04:31 PM   #1
ALS59LTD
Jeep Won't Idle ??
i changed my rear end fluid today....right after, I took my jeep for a spin around the block to see if i noticed a difference or not. well i sure did! on my way down the hill to my house the jeep died on me. i rolled back into my driveway and it wouldn't start. It will start and run when you hold the gas pedal even just a little. but when you release it, it just dies. i got it to idle perfectly once for a short time. then it died again. I was thinking maybe the idle air control valve is broken. any ideas?? thanks guys
-Alex
http://www.jeepforum.com/forum/f22/turbocharged-2-4l-jeep-tj-me-too-2255329/
ALS59LTD is offline   Reply With Quote Quick reply to this message
Unread 12-06-2002, 08:09 PM   #2
ALS59LTD
replaced the IAC valve. $80 later, runs like a champ.
-Alex
