Jeep will turn over but wont start, just replaced fuel pump - JeepForum.com
post #1 of 10 Old 05-07-2013, 11:30 PM Thread Starter
huntley1110
so i should have came here before i went and spent money that i might not have had to... but.
ever since i got my jeep ive had to let it turn over 3-5 seconds to start it, and this weekend i got up to go to work and it wouldnt start.. let it set for 15 min and it took a bit but it started....
worked fine all weekend after that, then on monday it took a crap again and wouldnt start this time, i could still hear the pump continuesly buzzing before i turned it over
I just spent my whole night putting in a pump and its still doing the same thing. Im not much of a mechanic and i am stumped at this.
any help would be amazing guys. Thanks!
huntley1110 is offline
post #2 of 10 Old 05-08-2013, 12:10 AM
SAR-Swimmer
Yeah, any help WOULD be amazing ! Not trying to sound like a jerk; but PLEASE fill in your jeep profile, so we know what you have. It's very hard for us to help you, if we know nothing about your jeep, such as year, engine size etc
SAR-Swimmer is offline
post #3 of 10 Old 05-08-2013, 12:27 AM
AaronButler
Generic things you can check:
fuel filter
see if you have fuel pressure by pushing in the bleeder valve on your fuel rail
AaronButler is offline
post #4 of 10 Old 05-08-2013, 12:39 AM
just_urd
If it's a 4.0, 3-5 seconds was normal for my old XJ to finally fire up, could be wrong if that's normal. But as ^^^ stated... Lots of people here to try and help.
just_urd is offline
post #5 of 10 Old 05-08-2013, 01:04 AM
Oldfrog
2007 WK
3-5 seconds isnt really normal for my 97 4.0. It turns over maybe 3 times and starts almost immediately.
If the fuel pump is humming constantly, that's not normal. I'd first try swapping out the fuel pump relay with the horn relay in the PDC ( that the fuse box under the hood) If it's a 4 litre engine ( the 6 cyl), those relays in there are all the same on a 96, as I recall. If it doesnt help, then it's something else CAUSING that relay to stay engaged....subsequently...the fuel pump is still running. I'm sure some of the guys here will know what else to check if that's the case.
Or you could do a search for the topic.
Meanwhile, help us to help YOU, by filling out your Jeep info on your profile.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #6 of 10 Old 05-08-2013, 12:33 PM Thread Starter
huntley1110
**** im sorry guys. i wrote this at 12 last night after working all day and 6 hours of doing that pump. its a 1998 gc laredo 4.0
and yes is is constantly humming, so i guess i will try to switch the relays around and go from there
post #7 of 10 Old 05-08-2013, 01:18 PM
jm8881
Aftermarket fuel pumps are usually of poor quality. Airtex, carter, and bosh (three main brands you'll find at autoparts stores) are terrible. Check your pressure at the fuel rail before going any further.
jm8881 is online now
post #8 of 10 Old 05-08-2013, 01:26 PM
Scopez
1994 ZJ
Any chance there's a jumper wire on the fuel pump relay? The PO decided to do that and it caused alot of my running rich issues. It still started fine, but once I removed jumper wire, it ran alot smoother.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #9 of 10 Old 05-08-2013, 03:33 PM
dellis
2005 WK
Yes, fuel pressure should be the first test to do. But, Bosch is the OEM supplier ... the Bosch I put in had Chrysler/Mopar labels on it.
dellis is offline
post #10 of 10 Old 05-08-2013, 03:40 PM
jm8881
Unless you bought it from the dealer it more than likely is not the same as a dealer part.
Bosch parts you buy in a place like Autozone or Advance Auto are much cheaper quality.
