Jeep took off on its own today!!! - JeepForum.com
post #1 of 14 Old 07-06-2013, 04:36 PM Thread Starter
jeeper1994
I have a 1994 Jeep Grand Cherokee. I started it and got out it was in park and not moving, I ran back in my house and when I came out the jeep had went backward down a hill and across the highway and into a ditch. Needless to say there is quite a bit of damage. I am the second owner and never thought to check to see if there were any recalls on the Jeep. I see there is a recall for the exact thing that happen to me...does anyone have any suggestions for me on any recourse I might have with Chrysler?? Any suggestions would be appreciated, even funny ones...
jeeper1994 is offline
post #2 of 14 Old 07-06-2013, 04:39 PM
caseyliffick
Well, it's definitely not their fault since they issued a fix for it... But that's why I always use my ebrake.
caseyliffick is offline
post #3 of 14 Old 07-06-2013, 04:43 PM
WhiteOut
WhiteOut's Avatar
Yeah, own up to not doing your maintenance and stop trying to pass the buck. It's not Chrysler's responsibility to hold your hand down to the dealer and inspect everything for you.
WhiteOut is offline
post #4 of 14 Old 07-06-2013, 05:02 PM
dellis
2005 WK
If you ask real nicely, they might give you a trailer hitch.
dellis is offline
post #5 of 14 Old 07-06-2013, 05:19 PM
dunkeye11
Lol yea shifter detent? If I'm right
Not sure though
Definitely have a working ebrake
dunkeye11 is offline
post #6 of 14 Old 07-06-2013, 06:12 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
shifter detent kit ...recall was B02 I think. It increases spring tension on the detent. And probaly makes the detent wear out faster.
Originally Posted by HighLonesome
coralman is offline
post #7 of 14 Old 07-06-2013, 06:56 PM
a70eliminator
Does your front driveshaft have u-joints or double cardan?
a70eliminator is offline
post #8 of 14 Old 07-06-2013, 07:04 PM
xcaliber81
Was it a costly mistake? Is your jeep totaled?
xcaliber81 is online now
post #9 of 14 Old 07-06-2013, 07:12 PM
xcaliber81
post #10 of 14 Old 07-06-2013, 07:47 PM
dnuccio
all of them have double cardan
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #11 of 14 Old 07-06-2013, 10:37 PM
kachink
This may or may not apply to you, but ZJ's with the early All Wheel Drive (249) transfer case will roll in park if the front drive shaft has been removed. This transfer case has a viscous coupling that wears out at about 100-125k miles. Owners who do not need 4wd will sometimes remove the front drive shaft instead of going to the expense of replacing the VC.
kachink is offline
post #12 of 14 Old 07-06-2013, 10:43 PM
a70eliminator
No No it was just a joke, expecting a reply like this......"what front driveshaft"
The front driveshaft was removed cause of the bad 249 and the guy doesn't even know it, and on a 94 it will roll away in park.
post #13 of 14 Old 07-07-2013, 09:26 AM
Marcos
Actually, it adds a completely separate second detent, with a modified cutout that more positively guides the shifter into Park. The secondary detent uses a roller tip instead of a sliding contact like the original.
Marcos is offline
post #14 of 14 Old 07-07-2013, 09:34 AM
coralman
coralman's Avatar
You are correct marcos. I have kit number ccxrb020 in front of me and there is in fact a roller.
coralman is offline
