Jeep Stalling ISSUE - JeepForum.com
post #1 of 6 Old 11-22-2002, 12:29 PM Thread Starter
JeepFreakCT
Jeep Stalling ISSUE (this is a TECH QUESTION)
Please don't reply if you don't know what your talking about
Need some help here....I'm not the best in the world with cars, more a computer person, but here is the issue. What would make my baby, stall in the morning when its coming out of the garage. I mean its not like all the power goes off or nething, all I see is that the RMPs drop to 0 and the engine baically dies on me. All I have to do is turn the key and give it some gas and off I go, sometimes I will have to repeat this a few time in the morning to get going. What could be the issue here....I use Fuel injection cleaners in my gas...other then that I don't know what else I could do to prevent it from cutting out on me.......please help if something know anything. Its a 97 Grand Ch Jeep V8 with about 85k on her.
"its a jeep thing you wouldn't understand"
Canadian Till the end
JeepFreakCT is offline
post #2 of 6 Old 11-23-2002, 05:27 PM
gcl97
It could be the O2 Sensor .... with 85K on the vehicle, I'll replace it anyway.
Did you do the tune-up stuff, clean throttle body, fuel injectors, spark plugs, distributor cap & rotar, air filter, etc.?
Is the CHECK ENGINE light on?
gcl97 is offline
post #3 of 6 Old 11-25-2002, 02:48 PM Thread Starter
JeepFreakCT
the O2 sensor has been replaced after I knocked it off...long story..and I have never missed a tune up on my car yet..and no the check engine light isn't on.
post #4 of 6 Old 11-26-2002, 10:27 PM
FHWilliams
I have the same STALLING problem with my '96 Grand Cherokee. The only difference is it sometimes quits running when decelarating to a stop after it gets going. It seems to go for days with no problem, then two or three days in a row will not stay at idle.
I just had a full tune up with O2 and MAP sensors replaced not more than 60 days ago. No engine light on or anything.
I'm running Shell 92+ octane and have put in two bottles of fuel system & injector cleaner in the last 4 fill-ups.
The one thing I think I'm noticing is that it does it when the fuel tank is below 1/2 to 1/4 of a tank.
I'm wondering if the pump is maintaining proper pressure in the fuel rail or if I'm having fuel pick-up problems.
Any ideas?
FHWilliams is offline
post #5 of 6 Old 12-01-2002, 02:00 PM
Hank
Hank's Avatar
If it's cold out, that could definitely do it. Has it been cold where you are? Cold weather will do just that to alot of cars.
Hank is offline
post #6 of 6 Old 12-01-2002, 06:32 PM
FHWilliams
Yes, it's cold, but not abnormally so here in Ohio, US. Weather didn't seem to matter whether or not it was 60 or 30F.
I was thinking of installing a crank angle sensor, but wound up fixing the "stalling" problem by selling the Grand Cherokee and getting a Lincoln Navigator.
I also have a '97 TJ and wouldn't suggest mounting tow hooks on the bumper. I'd think they need to be bolted to the underside of the front frame rails.
2002 Gr Cherokee Stalling Issue And Trans Issue darron99 ZJ Grand Cherokee Forum 6 02-03-2010 12:57 PM
98 ZJ 4.0 Stalling Issue nrdame ZJ Grand Cherokee Forum 0 07-15-2009 11:16 AM
'95 5.2 stalling issue goldygopher ZJ Grand Cherokee Forum 2 11-17-2008 12:18 AM
Need help with stalling issue bnhcooper ZJ Grand Cherokee Forum 3 10-20-2007 04:54 PM
93 ZJ stalling issue wilreyca ZJ Grand Cherokee Forum 0 09-15-2007 08:23 AM
