Jeep Shuts off after starting, then won't start back - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Jeep Shuts off after starting, then won't start back
Save on Rancho Products !All Bilstein shocks & struts - Lowest Prices Ever and TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROC
Unread 06-20-2010, 04:56 PM   #16
Marctwayne
Originally Posted by nlynd1978 View Post
Check and replace the Camshaft (not crankshaft) sensor. Can behave like the Crank sensor from what ive read in some threads.
No no replace what you want but the CRANKshaft position sensor in the more common failure then the CAMshaft position sensor.
Nothing "needs" to come from the dealer. That in its self is a generalization so ... but once you leave the dealership (if you even bought from one) there is rarely a reason to go back, except for warranty work.
The suggested flow of diagnosis and repair have been Crankshaft sensor then camshaft sensor fallowed by a possible PCM which is rare and expensive but nonetheless...
-- Marc Wilson -- 85 CJ7 Called Buster, Why? The wife likes to yell out the door "Are you done fix'en buster's bits yet"?
[QUOTE=my-jeep-earl;6694423]It does look alot better when the Jeep is "ugly side up" though! :hahaha::teehee:[/QUOTE]
Marctwayne is offline   Reply With Quote Quick reply to this message
Unread 06-20-2010, 05:04 PM   #17
nlynd1978
No, no, read what you want, he already replaced the crank sensor, twice. Thats why i said check the Cam sensor.
No it doesnt need to come from the dealer, but with the amount of thread on how the aftermarket sensors dont work in jeeps, he/she may want to get the mopar part.
01 GC Limited, Quadradrive, 4.0
Looking for help- http://www.jeepforum.com/forum/f13/completely-turns-off-while-driving-no-codes-1049268/
nlynd1978 is offline   Reply With Quote Quick reply to this message
Unread 06-20-2010, 05:11 PM   #18
Marctwayne
My bad missed the clearly diplayed highly informative "list".
Unread 06-20-2010, 08:44 PM   #19
jeep210
This is a resurrected thread. The OP dropped off in March and thread was brought back today. Maybe the OP will give an update on what he found.
jeep210 is offline   Reply With Quote Quick reply to this message
Unread 09-20-2013, 10:21 PM   #20
scottf24
How do you reset the alarm on the 1995 jeep grand Cherokee V8. I know the alarm is going off because the lights are flashing when I connect the battery but there is no sound to the alarm. Emergency flashers are off and headlights and turn signals are off.
scottf24 is offline   Reply With Quote Quick reply to this message
