#1 | |
Original GC'er
Jeep Shut Down Noise
Lately when shutting off the jeep it shuts down really rough and rattle really bad, sounds like the exhaust is knocking around. The exhaust is tight, and the motor mounts look to bee is good condition. I also get a metal rattle when driving, It sounded like the muffle bouncing around but everything is tight and bolted up. Also the noise (not sure if it is related) coming form the font passenger wheel, it rattles sometimes whines others. The shock and springs are new nothing looks out of place, the CV boot is still in tact and seems solid could the CV joint still be bad though? They are all odd noises that cant seem to pin point.
1993 Jeep Grand Cherokee Limited 4.0L I6 - OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap - 1970 Jeepster Commando 225 V6 32"x11.5" BFG A/T 4" Lift 1987 Suzuki LT230S Quadsport 1996 Artic Cat ZR580 EFI 2005 Honda TRX450R "For every one thing I fix two things break" |
#2 | |
Victim of Hope & Change
Location: . . . . . . . . . . . . . . . A shining city upon a hill
-Steve ___________________________________________ '98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap) '05 KJ Limited 3.7 Selec-Trac '94 ZJ Limited 5.2 Q-Trac- sold, after 17 years '67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC '06 Chrysler 300C SRT8 6.1L |
#3 |
Original GC'er
Cat is brand new. I cant place the noise, is there transmission mounts of any kind?
#4 | |
Could be a loose heat shield??? Kind of hard to tell from here ![]()
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!! ESSAYONS 97 F350 Dually CC Powerstroke- - 65 Mustang - 74 Super Beetle - 93 Harley Sportster 97 ZJ 4.0 4x4 Auto : Rusty's BB lift & Rusty's K&N intake 235 75 15 Toyo Open Contry AT's 15x8.5 Eagle alloy's Flowmaster exhaust, custom winch bumper, Ramsey 9000lb, THULE MOAB roof rack |
#5 |
Original GC'er
nah cat is fine, and that is what you get for buying a ford, I can wait for the company to go under.
#6 |
I have the same thing. I found that after the cat, the pipe turns up to navigate around the rear axle. At the point where the exhaust pipe starts curving back down I noticed that it is rattling off of the rear axle. I went out and bought exhaust wrap (usually used on performance cars) and wrapped the exhaust at that point and it has all but gotten rid of the rattle. The wrap is a little pricey but its cheaper than a new exhaust.
#7 | |
There is a trans mount.. on the dubs its attached to the cross member. could also be your heat shield, and if the cat is brand new... if the shop was rough durring install ie drop it.. which when they are getting paid all of minimum waige.. what do they care? Some of the internals could have gotten knocked loose, but i second the use of a broomstick to listen to the cat as you shut the jeep off.
as for the other thing, yes it does sound like you cv is wearing out, and yes it is possible for them to wear out before the boot does. Ma's subaru the boots outlast the joint all the time
-Jeb 99 WJ 4.7V8 selc-trac swap 285s re-tread IRO 6.5 Long Arms Aussie Locked Rear in the works... lots deployments are great for jeep budgets Go Doorless! Things i need.. good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share Quote:
#8 |
Micifus,
check the exhaust where the pipe comes up and over the track bar. If your exhaust hanger is just rubber it could sag and allow the exhaust to clang against the track bar when you shut the jeep off. I had this problem and made a custom hanger that allows me to raise the tailpipe which raises the section above the track bar enough not to hit. One more thing to look at is make sure the muffler is not "falling" to one side. If your muffler has an offset inlet or outlet the weight of the muffler and/or tailpipe can cause the muffler to twist at the connection between the cat and muffler and the tailpipe drop. This happened to me when the garage just tried to use exhaust pipe clamps to hold a 2" diameter tailpipe plus the weight of a stainless steel flowmaster muffler to the cat. I needed to get it tacked in place to keep it from moving. Good luck, turk
It doesn't matter what you drive as long as it is a JEEP. 98 JGC Laredo 4.0, 3" lift, Rustys adjustable UCA's & LCA's, Custom K&N intake, high flow exhaust, Jet chip Stage 2 and 32x11.5 BFG TA's |
#9 |
Micifus,
#10 |
Original GC'er
What size socket is need to replace the CV joint I would search for it by CV is to short of a word haha and I cant find it in the FAQ, i know its up there some where 32mm?
They just slide in and out right? 15 minutes job with an Ingersold and Rand air gun? I have never replaced them on the jeep and I have owned it for over 50,000 miles. They might be the orignal but I doubt it.
#11 | |
on a dub its something in the neighbor hood of 36mm.. its a big mofo... just get you one of those dial caliper things pull of the center jeep cap and measure that bad boy. the process is similar to replaceing the Hub bearing.. now mind you this is all for a dub, ZJ could be completly diffrent, so please soembdy chime in here if i am sending this guy off course, but I think Arlo has a writeup in his sig, on how to all this
#12 | |
#13 |
Original GC'er
Im convinced the noise is the muffler knocking off the rear sway bar or track bar. The muffler was clamped up and has now turned slightly and is knocking off the one of the bars. It must just vibe all the way up making it hard to pin point exactly where it is coming from.
#14 |
Original GC'er
uggg I found out what it was thses bleeping retards put the cross member support to far back and when it heats up it pushes back and bounces off the cross member. When will my exhaust nightmeres end?
#15 |
I was going to say check your exhaust hangers.. Mine did that for a while.. a BFH and my foot took care of that..
1996 ZJ Orvis Edition,V8 5.2L Tow & Skid Package, FM 40,44a - 3.73, NP249 265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top; OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier Proud To Be A FF/EMT/Police/Military Club Member #15 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
