Jeep is running rich and misfiring, sometimes. - JeepForum.com
post #1 of 12 Old 09-14-2009, 01:29 PM Thread Starter
impuresoul2k3
Most of the time, my Jeep runs fine, albeit gas mileage is a little low (~13). On longer drives though(20mins+), it will out of the blue just start missing (can't cruise 60 mph, it misfires too much) and/or running extremely rich. I know it isn't that accurate, but the overhead console will estimate the mileage as dropping to 7-8mpg instead of the 20 or so it should be getting.
Turning the engine off and restarting doesn't help. You have to shut it off and let it cool down. Occasionally, possibly rarely, it will correct itself and start running normally again, but that doesn't last long.
Within the past year or two I have replaced:
  • TPS
  • Oxygen Sensor (a few months ago I believe)
  • Coolant Temp Senor
  • Plenum Gasket
  • Plugs
  • Wires
  • FPR
  • Oil Pressure Sensor
  • Battery
  • Radiator
  • Coolant Hoses
  • Heater Hoses
  • Air filter has been cleaned
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #2 of 12 Old 09-14-2009, 01:41 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Probably O2 sensors, maybe a bad cat. Not sure how many O2's the 5.2 has (you hinted towards only replacing one) It could be you got a bad one, or did you go mopar? If not, change them to mopar sensors.
~James
ezflip is online now
post #3 of 12 Old 09-14-2009, 02:01 PM
rugermack
My 95 5.2, has one O2 sensor.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #4 of 12 Old 09-14-2009, 02:08 PM
JackieChilesEsq
I have a '96 and I have the same problem. The thing would barely go when I cranked it this morning. The longer I drove it, the better it ran, but still doesn't run great.
I took it by Auto Zone and they came up with the following codes:
1. 1. Throttle Position Sensor/Pedal Position Sensor circuit high input, code PO123
2. 02 Sensor Circuit High Volts Bank 1 Sensor 2, code PO138.
What will it take it terms of cost, roughly, to get these issues fixed?
JackieChilesEsq is offline
post #5 of 12 Old 09-14-2009, 02:29 PM Thread Starter
impuresoul2k3
I forgot to mention, sometimes in the mornings, when its a cooler morning, the engine will idle real low (~200rpms) and quite rough unless I hold the idle up around 1500 for a few of seconds. Without intervention, it will sometimes stall. It also seems like if I push down the gas pedal to move forward in a line or stopped traffic or something, it will misfire a little bit if its 1200 rpms or under.
The 93-95 Jeeps have only one O2 sensor, mine probably has around 2500 miles
Air hat spacer
Flowmaster muffler
post #6 of 12 Old 09-14-2009, 02:41 PM Thread Starter
impuresoul2k3
And last bit of info, I don't have any codes
Air hat spacer
Flowmaster muffler
post #7 of 12 Old 09-14-2009, 02:46 PM
WiCkeDuDe
What brand O2 sensor did you put in?
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #8 of 12 Old 09-14-2009, 02:52 PM Thread Starter
impuresoul2k3
NGK. If it was the O2 sensor, wouldn't it manifest itself well before a 20-30 minute drive?
Air hat spacer
Flowmaster muffler
post #9 of 12 Old 09-14-2009, 03:18 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Not necessarily. Only after a bit of a drive is your jeep up to normal operating temps. Temps affect greatly if you run lean or rich. O2 sensor is probably wear I would start.
~James
post #10 of 12 Old 09-14-2009, 03:43 PM
StellaTheZJ
The Crankshaft Position Sensor tends to go bad on a lot of our Jeeps. Many people have reported strange and intermittent missing can be cured by installing a MOPAR CPS. You've covered most bases, but left the coil, CPS, and Cam Position Sensor (inside the distributor). How about one of them?
Also, have you checked the ASD Relay for corrosion? Corrosion causes increased resistance with heat, and again, many have reported problems with the ASD relay.
Good luck!
StellaTheZJ is offline
post #11 of 12 Old 09-14-2009, 04:08 PM Thread Starter
impuresoul2k3
Good call Stella, I think I'll check those out before the O2. I mean the Jeep is up to operating temp plenty of time before it starts misfiring.
Air hat spacer
Flowmaster muffler
post #12 of 12 Old 09-15-2009, 10:23 PM Thread Starter
impuresoul2k3
Ezflip, I stand corrected haha. I had a friend hook up his scan tool and it turns out the O2 sensor starts reading lean, ~.1V and the fuel trims max out at +33%. Looks like its going back for a refund...
Its still kind of weird that it takes a longer-ish drive to get it to start running crappily
Air hat spacer
Flowmaster muffler
Rich running/backfiring issues with my Grand Cherokee Country Boy ZJ Grand Cherokee Forum 31 04-27-2008 11:33 AM
95 GC V8 running rich camosilver ZJ Grand Cherokee Forum 1 09-17-2007 03:05 PM
Running rich while towing, 96 Grand Cherokee mcfadds ZJ Grand Cherokee Forum 10 08-17-2007 03:48 PM
Help Techs: Running Rich at Hot Startups Scott98GC ZJ Grand Cherokee Forum 10 06-01-2006 09:05 PM
Running rich/missing Choff ZJ Grand Cherokee Forum 8 02-28-2004 10:32 PM
