Jeep running cold? - JeepForum.com
post #1 of 4 Old 04-13-2013, 01:31 AM Thread Starter
Nate620
Junior Member
noticed my temp was sitting about 150-160 and its usually at 200/210. I had my heat on defrosters as hot as possible and on a low blowing, I turned it all the way up and put it to the vents and the temp went right up to 210... I then noticed it went down to running cold once more and while I was driving I watched it and it would go back and forth between 150 and the 210 mark... Is this not good? What could be causing it? The unsteady temp was going pretty fast back and forth, it has coolant and I just changed the oil yesterday...
Nate620 is offline
post #2 of 4 Old 04-13-2013, 02:12 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
year, engine, trim level?
basic information we need to make any kind of diagnostic attempt.
ratmonkey is offline
post #3 of 4 Old 04-13-2013, 06:05 AM Thread Starter
Nate620
Junior Member
1998 zj 4.0, limited 153k. Has the Quadratrac x case
Nate620 is offline
post #4 of 4 Old 04-13-2013, 10:57 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
sounds like a sticky thermostat or air in the system. i'd start by replacing the stat(only a 5$ part with a 1$ gasket) and do a coolant flush/fill. be sure to disconnect the heater core hoses and do a back and forward "power" flush on it with a garden hose.
