Jeep rolls on even surface... T-case is bad? - JeepForum.com
post #1 of 4 Old 09-07-2013, 01:24 AM Thread Starter
orvisss
So, guys. Finally my jeep gets lots of love, I even drove that thing to junk yard to pickup misc stuff for it. It made it just fine (about 100mi that day)
And this is when I discovered that jeep rolls on uneven surface. It does it very slowly, almost invisible, but everytime I got back it was in different spot. I was like "I could swear I parked closer". And yes! I've used E-Brake. Living in Seattle and in SF gave me that unkillable habit (I use it even on flat surface).
So I've discovered, that E-Brakes don't work, will have to fix that. And... It rolls when in P position.Is it a transfer case? Or transmission? I promised here not to do anything with T-case while it is good, well, the swap/VC fix will have to be performed sooner than I thought
orvisss is offline
post #2 of 4 Old 09-07-2013, 02:26 AM
Oldfrog
2007 WK
Dont know about the 95, but there was a recall on the 97 to fix the park detent/or pawl in the tranny.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 4 Old 09-07-2013, 02:24 PM
PolkaPower
Never heard of a bad VC causing the Jeep to roll. If anything it would bind it up and cause it not to roll. 93-95 will roll in park with the front drive shaft removed.
I believe there is a recall on the parking lever too.
To test the VC do tight figure 8's lock to lock. If it takes a lot of gas to move it and feels like it's hopping and binding then the VC is bad.
PolkaPower is offline
post #4 of 4 Old 09-07-2013, 02:30 PM
JColee
In my 1997 Limited ZJ, after driving about 300 miles with a bad VC, I parked at a McDonalds to grab some wifi and while my Jeep was in park and turned off it would keep... lurching forward maybe a half an inch or so every few seconds. It only did it once, and I could never get it to do it again. Not sure if it and the bad VC were related though.
JColee is offline
