Jeep rocker panels - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Jeep rocker panels
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 12-06-2014, 10:35 AM   #1
ESUBOSTON
Jeep rocker panels
My rockers need replacing should I have them professionally replaced and how can I save some money on the job. How do I prevent dirt etc..from getting into the panels in back of the front wheel.. Is there an easy way of repair?
thks
ESUBOSTON is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 05:57 PM   #2
neverXalone
A lot of people use steel tubes to make sliders. You can do a quick search and see what people usually do for these. A lot of people have said its up to 1000 to get a shop to fix them. I havent repaired mine personally but have been researching around this board on the same topic.
Edit: Im also from Massachusetts. Sup?
95 ZJ I6
FHRITP
Instagram: bootxparty
neverXalone is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 09:40 PM   #3
chaZJones
Enthusiast
chaZJones's Avatar
cut the rockers out and weld in some steel box tube. 2x6 would be nice for sliders/step
96 ZJ 5.2L 156k
chaZJones is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 01:55 PM   #4
durango-bob
This is what I have planned. As soon as I find the time.
durango-bob is offline   Reply With Quote Quick reply to this message
Unread 12-08-2014, 07:50 PM   #5
ESUBOSTON
rocker panels
what is a slider?
Unread 12-08-2014, 07:52 PM   #6
ESUBOSTON
I'm in East Freetown mass... wish there was someone around who knows the ins and outs of the jeeps ... I think someone in tauton
Unread 12-08-2014, 10:10 PM   #7
Uniblurb
Uniblurb's Avatar
A slider is a HD piece of metal, like the 2x6 box steel mentioned, which replaces the rocker and normally for off-road use. Like sliding on rocks, logs, etc..
If you're wanting to stick to stock rocker panels Rockauto carries them at some fairly descent pricing. Usually there's an inner and outer rocker. I've seen more of a selection on their site but would think for $123/each these might be both welded together but could just be the outer.
http://www.rockauto.com/catalog/mor...088&cc=1315963
The left one would be part #08504AL. If you don't weld you'll have to find a body shop to cut the old ones off and weld the new ones on. You may be better off finding a small shop or asking around about welders in your area. Good luck.
PS. Go into your account at top of page > click on edit Jeep info on the left side > under model select ZJ > save changes button at the bottom. A XJ is just a Cherokee while a ZJ is a Grand Cherokee (93-98).
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is offline   Reply With Quote Quick reply to this message
Unread 12-09-2014, 09:02 AM   #8
Timo_90xj
Timo_90xj's Avatar
To the OP, just consider this:
No matter of style done, a rocker panel replacement will take between 1-2 days. have a shop do it, and it'll cost you plenty of money.
Box steel rockers are the way to go, no matter if you're ever going to wheel it or not. Why? It's much easier to do in the end. Stock rockers are sandwiched between multiple plates (mainly on the a-, b-, and c-pillar areas), they consist of at least an inner and outer panel, and to do the work properly, there are a gazillion spot welds that need to be drilled open, then separate/ pull out rocker plates, clean ALL rust, etc... only then you can start welding in the new ones.
In other words, trying to replace with stock style rockers is a LOT more work than doing box steel rockers. Box steel rockers: cut two straight lines (one from the bottom side of the Jeep on the vertical floor pan section, one right below the door sill), burn in 2 x 6 box steel, paint. Search for box steel rockers either on ZJ- or XJ- tech section. Principle is the same on both, measurements are slightly different. Check out my ZJ build thread on my signature.
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is online now   Reply With Quote Quick reply to this message
Unread 12-09-2014, 09:21 AM   #9
Uniblurb
Uniblurb's Avatar
Some real good info Timo and in not replacing rockers myself I've learned something!
Unread 12-09-2014, 12:23 PM   #10
kg6mov
Hears the voices
kg6mov's Avatar
I'm going to be cutting off my current sliders and then cutting up the rocker for box steel in a month or two.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 12-09-2014, 12:51 PM   #11
1ATony
Vendor
We carry new rockers for your ZJ here's a link to them if anyone wanted to check them out. Jeep Grand Cherokee Rocker Panels
Call our sales staff 866-403-3393
Facebook|YouTube|#1AAUTO ON INSTAGRAM
1ATony is offline   Reply With Quote Quick reply to this message
Unread 12-09-2014, 01:06 PM   #12
kg6mov
Hears the voices
kg6mov's Avatar
$230 will buy a lot of steel . . .
Unread 12-16-2014, 08:31 PM   #13
ESUBOSTON
Ok Jeepsters....Can you believe your on line with a 71 yr old jeeper. My ZJ is 6 cyl and 98k orginal miles 3rd owner. Runs like a clock and never a tune up. Fantastic automobile. My grandson wants bigger tires and loves to hear that engine perform. All original and I get many comments. It's my 2nd car for general runs around town. I want to keep her I do need to get the rims taken care of..seems like a clear coat is pealing..true? Anyway, pse keep me imformed. THANKS
Unread 12-17-2014, 07:42 AM   #14
zarnold
Here is a video of rocker replacement with 2x6 steel tube. The design on this one is a little unique (to me anyway) because the tubes don't have supports which are welded to the main uni-body frame rail.
http://www.projectzj.com/videoupdate...liders-part-1/
zarnold is offline   Reply With Quote Quick reply to this message
Unread 12-17-2014, 08:30 AM   #15
Timo_90xj
Timo_90xj's Avatar
That's pretty much exactly how I've built mine. If I was doing more hardcore offroading with my ZJ, I would definitely add the support legs from the rockers to uniframe. However, I've dropped my ZJ from at least two feet high ledges flat onto a rock, I've banged them MANY times pretty hard on rocks, and I have had zero issues. I have multiple dents on the tube extensions on both sides, but nothing on the rockers
