Jeep Overheating/Smoking - JeepForum.com
post #1 of 8 Old 07-08-2011, 01:46 PM Thread Starter
Zj1994
1994 FSJ Cherokee
I have a 1994 Jeep Grand Cherokee 5.2. For the last three years, it has had a problem with overheating in the hotter months of the year, but only if the air conditioning is on and the Jeep is idling. I recently had the transmission rebuilt, as well as a complete overhaul of the coolant system (water pump, thermostat, radiator, fan clutch, hoses). We also replaced the AC compressor. The problem still persists, and there is a lot of white smoke being emitted from the exhaust, especially when idling. The smoke problem started about a year ago. We are completely baffled at what this problem could be. I know it isn't a faulty gauge because the Jeep begins to sputter and the RPMs decrease when the gauge reads hot.
Zj1994 is offline
post #2 of 8 Old 07-08-2011, 02:16 PM
sebian
Sounds like a possible head gasket issue, or warped/cracked cylinder head. Especially with the white smoke from the exhaust.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #3 of 8 Old 07-08-2011, 02:17 PM
yzjwk
2005 WK
White smoke = blown head gasket . That could be the problem .
Good timing Sabian
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #4 of 8 Old 07-08-2011, 10:42 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
How could white smoke from the exhaust be that baffling? Classic symptoms of a blown head gasket or cracked head.
ratmonkey is offline
post #5 of 8 Old 07-08-2011, 11:14 PM
phitmein
phitmein's Avatar
too many unknowns here maybe ...
I see grey smoke at start-up, till it's hot and I am adding a ship load of coolant for the last year or so ..
or not ???
Are you adding coolant ???
Also: " as well as a complete overhaul of the coolant system (water pump, thermostat, radiator, fan clutch, hoses"
new heater core ???
phitmein is offline
post #6 of 8 Old 07-10-2011, 08:20 PM Thread Starter
Zj1994
1994 FSJ Cherokee
If there was a cracked head or head gasket would there not be water in my oil?
Zj1994 is offline
post #7 of 8 Old 07-10-2011, 09:09 PM
phitmein
phitmein's Avatar
Are you having to add coolant or not ???
Remove your oil filler cap and look on the bottom of it for signs of moisture ...
Edit: did you replace your rad. cap too ???
Phit
phitmein is offline
post #8 of 8 Old 07-11-2011, 10:53 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Not necessarily. Could get oil in coolant, coolant in oil, oil in cylinder, coolant in cylinder.
Smoking and overheating _AdriaN_ ZJ Grand Cherokee Forum 4 08-16-2009 01:53 PM
Jeep overheating without AC on. singhZJeep ZJ Grand Cherokee Forum 11 04-30-2009 09:07 PM
I quit smoking years ago, but the jeep seems to have started !! madmarchhare ZJ Grand Cherokee Forum 7 08-27-2008 08:00 AM
Help! Jeep Smoking MickeyZJ ZJ Grand Cherokee Forum 1 06-10-2008 10:32 AM
After Overheating, Jeep misfiring, help! chourki ZJ Grand Cherokee Forum 4 10-18-2005 08:47 PM
