Jeep Maintenance - JeepForum.com
post #1 of 20 Old 09-01-2013, 06:51 AM Thread Starter
jeffjeep2
Jeep Maintenance
Hi Guys, ill be posting on this thread on what I have done on my jeep and how it is now,
Got this jeep as 3rd owner and the last owner just used it and used without
maintenance.
Im using this as a street jeep, daily office use and not much of an off roader.
Here is what I have done so far.
1. rebuild the rear differential by mechanic ( I should have just bought a whole rear assembly, the sound is still there)
2. change engine oil
3. change transmission fluid
4. change front diff fluid.
5, remove noisy front DS
6. Change brake pads
7. flush radiator, and new cap 18 lbs
8. change belt, idler pulley and tensioner pulley.
9. tie up the ac vent louver to have a front air exhaust while hunting for the leak.
10, change horn and replace button, faulty clock spring.
11. change seat covers
12. change 17 inch rims ( should have been 18)
13. cleaned the IAC
here are the things I need to put back that I have,
1, cv shaft for front
2. new windsheild washer
3. bleed the brakes
4. new thermostat -- (temp rising)
Suggestions very much appreaciated, JY is 350 km away , finally found it
Jeff
jeffjeep2 is offline
post #2 of 20 Old 09-01-2013, 05:33 PM
shaban
Hi!
- Whats wrong with your front driveshaft, and why do you want to put a CV shaft in the front anyway? U-joint shafts last longer.
- Regarding the windhield washer - what part of the washer, the pump or the nozzles?
- Brakes: not too hard just make sure you don't run the reservoir dry, air can get trapped in the ABS pump and you can't bleed ABS pump without a special tool.
- Thermostat is pretty easy to do too, make sure you clean both surfaces before putting them back, and the hole in the thermosat housing should be on top.
shaban is offline
post #3 of 20 Old 09-02-2013, 08:13 AM Thread Starter
jeffjeep2
Thanks for the advice.
My front DS is a rezpa cv, the boots were torn and giving a clunking noise so i removed it.
My tc case is due for replacement too, but ill put in a 249 because no good mechaniic. I have dint have the previledge to do it my self most of the time.
Yup brakes, i nver taught about the abs pump
the windshield washer, both pump faulty the JY sells the whole container with both pump.
2007 Compass
2000 WJ QD now working
ZJ 4.0 I6 sold ( i miss it)
post #4 of 20 Old 09-16-2013, 10:18 PM Thread Starter
jeffjeep2
wind sheild washer in
front drive shaft in too, now quadra track working Happyyyyy!
But radiator electricfan now only working on high speed, but puzzles me,
the temp seems to sit i bar below 100, this is good for me, it never done this when it was on 2 speed.
looking again fior the fan in JY
post #5 of 20 Old 09-16-2013, 10:53 PM
Mickey_D
Check the input signals to the fan relay. For the most part, if a fan works at all, it works. If it's only working on one speed, then most likely what's wrong is what is telling it to run.
And my personal opinion ZJ's should ALWAYS have 15" tires on them. 31X10.50X15 to be exact. A 2" budget boost and 31's leave a ZJ looking like what it should have come from the factory. At least in my opinion.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #6 of 20 Old 09-16-2013, 11:23 PM
NinetySevenZJay
should they?
NinetySevenZJay is offline
post #7 of 20 Old 09-17-2013, 04:17 AM Thread Starter
jeffjeep2
Hi Guys,
I still keep the stock 15, im trying to have 18 with 50 series or 17 with 60
series, reason stability, we live in UAE and even its a dessert area most road are nicely cemented and flat I stability when turning and start from the stop light, actually bought the wrong ride, i should have just opted for a wagon car or CRV, but what can I do, the jeep is the best i can afford then
so just fixed it up to suite my needs.
I tested the fan directly to the battery, this time only the high is working the other wire when connected to the batter does not move the fan, this was before moving when i tested them both.
do you know which triggers the high speed, because the low. i found it but the hi havent figure out yet?
jeff
post #8 of 20 Old 09-17-2013, 09:48 AM
JeepNicholson
Are you talking about your radiator fan, or your interior blower fan?
JeepNicholson is offline
post #9 of 20 Old 09-17-2013, 12:41 PM
Mickey_D
Originally Posted by NinetySevenZJay View Post
should they?
As I said, in my opinion, yes.
I think just about every Jeep made looks best on 31x10.50x15's. But that's just me.
________________
#4
Mickey_D is offline
post #10 of 20 Old 09-17-2013, 02:56 PM
zj97ltd
Do yourself a favor and replace radiator hoses while you're doing the thermostat. And definitely do the little bypass hose above the water pump. Changing it in a 7-11 parking lot is no fun.
zj97ltd is offline
post #11 of 20 Old 09-17-2013, 05:24 PM
pageman
do yourself a favor and get 5 new tires and keep your VC from going bad also you said your outting in a new 249,you might as well do the vc i only paid 300$ for mine on ebay from transparts but also buy the rear bearing 206-l(national bearing part number) useualy if the vc went bad that bearing has gone as well
pageman is offline
post #12 of 20 Old 09-17-2013, 07:06 PM
zj97ltd
Ft. Myers? Wow small world.
zj97ltd is offline
post #13 of 20 Old 09-18-2013, 07:40 PM
pageman
lol yah what do ya know.the jeep club and i are heading to domestic in san carlos park sun at 12 your welcome to come.
and now back to the original thread
pageman is offline
post #14 of 20 Old 09-20-2013, 06:41 AM Thread Starter
jeffjeep2
Talking about the radiator fan. Tc ill do a direct 249 swap from jy not much good mechanics here. Tires yup real soon.
2007 Compass
post #15 of 20 Old 09-30-2013, 01:53 AM Thread Starter
jeffjeep2
Thank You God!!!!
its running more than just sitting in the sun due to repairing.
Im beginning to enjoy the jeep now, tested the quadra track its working!
able to use my windsheild washers yeheyyy
brakes are better yehhhhh
radiatorfan working good even in single speed waiting for the replacement part
Im still saving up for a new TC, this time a 242 I hope so.
after that will be seats, do other brand cars or trucks seats bolt in to a GC?
