Jeep Hesitaing when it gets warm - JeepForum.com
post #1 of 6 Old 08-21-2002, 02:46 PM Thread Starter
monch66
My 94 Laredo works like a charm untill it gets warm, then it starts to sputter and refuses to go faster no matter how much gas you give it. I have replaced the cps and the plugs,wires and distributor but it still happens. There are a couple of theories that I have heard : 1 is that the computer is going south or 2) that there is somthing restricting the flow of exhaust. The second my be true because I have noticed this problem since I had my muffler replaced in june. Any suggestions?
Thanks in advance.
Monch66
94 JGC
monch66 is offline
post #2 of 6 Old 08-21-2002, 03:10 PM
wadger
I can't tell you what the problem is, but perhaps your on-board diagnostics can. I think cherokees through 1997 have the on board diagnostics - if something is wrong with your engine or emissions, the OBD will most likely let you know. Put your key in the ignition and turn it (but don't start the engine) to ON, OFF, ON, OFF, and then turn it to ON and leave it. You have to do this sequence in under around 3 seconds. If your powertrain control module has any trouble codes stored, the check engine light will flash. The codes are two digits. Example: a trouble code 35 would be 3 flashes, a pause then 5 flashes. (more than 1 code will be separated by a long pause)
If you try this and get trouble codes I'm sure that if you post them, someone here can let you know what they mean. I hope this helps ya.
wadger is offline
post #3 of 6 Old 08-21-2002, 04:04 PM Thread Starter
monch66
Thanks Wadger but I have already had it run through diagnostics but there are not codes showing up.
94 JGC
monch66 is offline
post #4 of 6 Old 08-21-2002, 04:36 PM
MadDogg
just some things you might want to check out:
1) catalytic converter isn't plugged up
2) EGR valve is working ok (if you have an EGR system)
3) whatever system(s) that functions like a choke (idle air control sensor circuit?)
4) O2 sensor
5) fuel pressure (plugged fuel filter or faulty fuel pump)
those mechanics love to replace stuff that works fine... especially the computer. Sounds to me like you're not getting fuel or air to the engine (as long as the exhaust isn't plugged up)
MadDogg is offline
post #5 of 6 Old 08-22-2002, 04:03 AM Thread Starter
monch66
It seems to be gettng all kinds of gas, The Mechanic and I drove it with the fuel pressure guage on it and it is never being starved of off fuel. As far as the cat converter is concerned, I did have the muffler replaced in june and it has been getting worse since that time. I noticed that the mid pipe is a lot smaller than the one that was replaced. Could this be causing this?
94 JGC
monch66 is offline
post #6 of 6 Old 08-22-2002, 08:11 PM Thread Starter
monch66
Hey MadDogg, It looks like you might be right about the cat converter. A quick test will reveal if it is plugged. Start the engine and let it idle, wait untill it warms up and then get someone to put thier hand behind the exhaust. then gun the engine, if the hand is not pushed back then it is probably blocked.
Thanks all.
94 JGC
monch66 is offline
Very Slow to Warm Up CRD Hangloose WK Grand Cherokee & XK Commander Forum 25 11-23-2015 11:15 AM
4.0 zj - takes a while to warm up... graffix000 ZJ Grand Cherokee Forum 8 01-12-2009 07:58 AM
warm weather is here and need some help gs8hfl21 ZJ Grand Cherokee Forum 1 06-07-2008 08:04 AM
How to keep Jeep warm during winter?? FightingSioux ZJ Grand Cherokee Forum 32 12-01-2006 12:05 PM
stalling when warm ljmcdonnell ZJ Grand Cherokee Forum 8 09-24-2006 03:13 PM
